Used Razer Blade 14 worth it?
Go to solution Solved by Wellingtonzed,
if its the same one you linked, alright, just know that Razer has notoriously bad reliability.
If your looking for a portable gaming machine there is the Zephyrus G for about $999. 1660 TI Max Q, ryzen 73750H, 76WHR battery, etc... Just know its an Asus and they dont have the best out of the box quality control so make sure everything works out of the box. If it does, then your set.
Its more of a gaming machine first, but its small enough and lasts about 5-6 hours depending on your use.
I've been looking for a laptop as I haven't had one for years now. I've been looking around locally and ideally I would want a Dell XPS 15 with a gpu.
I came across this Razer Blade 14 this guy is selling for $810. The reviews on it don't seem promising and I'm not sure if it would be worth it. It definitely seems like a good deal. What do you guys think?
Ideally if anyone has recommendations I would get...
Best specs possible with a regular HDD since I have my own SSD for replacement.
https://linustechtips.com/topic/1118218-used-razer-blade-14-worth-it/
