Plenty safe as long as you don't try to breathe the water. I free dive down to about 30 to 40 feet when I'm home.
Current Build
AMD Ryzen 2600
Stock cooler
Asus ROG B450f gaming Mobo
1tb SKHynix m.2
WD 1TB HDD
Asus ROG Strix RX 5700xt
Thermaltake Toughpower 650w DPS RGB 80+Gold
16 Gigs ddr4 3000 gskill ram
Phantek fans
Phanteks P400TG
Laptop
Eluktronics Prometheus XVII
Ryzen 7 5800h
32 gigs ddr4 Corsair ram
Nvidia rtx 3080 max-p
17.3 qhd 165 hrz screen
1tb Samsung m.2
1tb WD black m.2
25 minutes ago, Dinesh1 said:
Is going under water 15 feet safe. Will pressure level cause problems. I havent gone underwater before.
Never been swimming in a lake or pool?
Yeah, don't breathe underwater but you can open year eyes etc.  Or wear goggles.
No issues besides feeling a little pressure in your ears possibly.
Onyx: AMD Ryzen 7 7800x3d / ASRock Taichi 7900xtx OC / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 1000 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
OnePlus Ecosystem:
Other Tech:
Just now, JoeyDM said:
Then maybe start at a bit more of a shallow depth.
I can't believe we are actually talking about this...
But you know that in a 15 foot deep pool... there a lot of other depths you can submerge yourself?
I'm laughing while I type this.  Hell, just fill your damn bathtub up for starters!!!
OnePlus Ecosystem:
Other Tech:
Personally I have a hard time when going lower than right around 4 meters (about 13 feet) and lower. That was unassisted though (no wetsuit, earplugs, flippers, etc.). But everyone is different in that regard.
Whether you should do it, is totally up to you. If you have never gone underwater before, you probably shouldn't go swim 15 feet deep right away. You could very well overwhelm your brain or heart with the levels of pressure you might not be accustomed to.
On top of the pressure in your ears, you will also have quite a bit of pressure on your face in general (eyes and nose), because of the (I assume you will use them) goggles you're wearing. Swimming down can also be difficult on your legs and arms (and thus torso too) because of the quite a bit of strength you might need to swim down (especially in salt water).
12 minutes ago, Velcade said:
Make sure you can swim or at least tread water before you going jumping in.
This is some great advice too, non sarcastic. If you (OP) have never gone underwater before, you should really consider if you are adapt enough at swimming in general before attempting this. Please be careful.
Oh seems like i should go feet by feet. Thanks
Something about learning to walk, before you start trying to run ;)
Everyone's body reacts differently to certain circumstances (like swimming in deep water), which means perhaps you can just swim 15 feet deep already, but you really shouldn't do that right away before 'testing the waters' so to speak.
Yes, it's safe. Just don't breathe in water.
