So basically i’m considering two pc builds and i’m pretty new to it, Id like you guys to help me check compatibility and optimize it. I’m planning on programming new games as well as gaming in general. I appreciate all help in advance!
AMD Build
https://pcpartpicker.com/list/4vTZRk
Intel Build
https://pcpartpicker.com/list/2MBzYH
https://linustechtips.com/topic/1118145-need-help-with-compatibility-and-specs/
The AMD build looks a lot better... On both instances however you'll want to go with a different power supply.
Personal Desktop":
Luna, the temporary Desktop:
Like Luna said, the AMD system looks better.
Also if you want to have less hassle, i'd pick a tomahawk MAX for motherboard, maybe the Gaming pro also has a MAX version. They should support 3000 series out of the box due to larger bios size.
You may want to consider getting a 3200mhz memory kit instead of the 3000.
Also, is there any specific reason you are opting for an NVME drive? SSD might save you a few bucks, and from personal experience, for gaming and windows it doesn't make a whole lot of difference (nothing noticable anyhow).
Gamesystem: X3700, 32GB memory @3200mhz, GTX1080 Hybrid
Unraid system: Epyc 7352, 24/48, 96GB ECC buffered @2666mhz, 2x GT710, GTX1050Ti
AMD Build
Intel Build
Welcome to the forum!
I edited your amd built a little. Much better psu, better/OoB working motherboard and added a slight cheaper 1TB SSD. Left the rest as is
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
PCPartPicker Part List
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  ($327.89 @ OutletPC)
Motherboard: MSI B450-A PRO MAX ATX AM4 Motherboard  ($103.98 @ Newegg) the board you picked was at $150.
Memory: G.Skill Aegis 32 GB (2 x 16 GB) DDR4-3000 Memory  ($106.99 @ Amazon)
Storage: Inland Premium 1 TB M.2-2280 NVME Solid State Drive  ($110.99 @ Amazon)
Video Card: Gigabyte GeForce RTX 2070 SUPER 8 GB WINDFORCE OC 3X Video Card  ($499.99 @ Newegg)
Case: Corsair iCUE 220T RGB Airflow ATX Mid Tower Case  ($109.99 @ Amazon)
Power Supply: Gigabyte 750 W 80+ Gold Certified Semi-modular ATX Power Supply  ($69.99 @ Newegg)
Total: $1329.82
Generated by PCPartPicker 2019-10-28 08:01 EDT-0400
Ah okay i’m seeing in these replies the power supply is bad or the like idk that so thanks!
55 minutes ago, Genwyn said:
The AMD build is significantly better, just note that as mentioned on the site you will need to do a bios update if the board isn’t listed as having the bios update preinstalled.
I think AMD still offers its loaner cpu service to do that but ask the retailer if it’s updated.
Then again it’s an MSI board and I don’t know the list by heart but most of theirs have a feature to update without a cpu.
The 212 evo sucks, either go stock or get an actually good cooler. Arctic Freezer 34 or BeQuiet Pure Rock for cheap, Dark Rock Pro 4 or Noctua NH D15 for high end.
If you’re gonna go Seasonic for the psu go for the prime lineup. The focus golds are OK but have some issues I’m certain someone else will elaborate on.
Ahh okay i’ll make sure to check that and I wasn’t aware the 212 evo was bad lol, also thanks for telling me about the psu I wasn’t aware of that.
I went for the NVME drive as I had seen videos were it loaded faster so i just opted for it, as for the ram that sounds better thanks!
Thanks I actually never thought to get advice on here till I saw a couple of questions I had be answered here. Thank you for the help though, I am not too sure what the OoB stands for but without all of the replies I wouldn’t have known that psu wasn’t good so thanks. Also if I am planning to OC is 550w going to be able to support that?
Total: $1329.82
thanks for the help, is the case fans not needed for this?
the case fans included should be good enough.
I run a 2700x + 2070 both OC'd with a RM550x. SO Yes, 550W will be enough :)
OoB=out of box :)
6 minutes ago, Kobe Smith said:
just to make sure but is the voltage the same with a 2070 super 3 fan?
Not sure what voltage has to do with anything here, but I assume you mean wattage; yes it will be enough
