Hey so I wasnt really sure where to post this but here we go:
I am planning to buy a monitor (LG Electronics 34WK95C-W, 34") and a new GPU (RTX 2070 Super). Since the card and the monitor both have a USB-C port, so I was planning to use those. Now, since the monitor also has 2 USB 3.0 ports, do these ports still work since the monitor is plugged into the GPU via USB-C? I thought about using these ports for the wireless receivers of my mouse & keyboard (MX Master 3 & MX Keys).
Thanks in advance for your help!
RTX cards use a technology called VirtualLink, which can provide graphics, power and USB 10Gbps bus to whatever device you connect there. So in theory it should work. I don't have anything to back it up though.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
6 minutes ago, jj9987 said:
VirtualLink
I thought this was only for VR
What are you using the 2 Displayports and the HDMI for?
My life
It is. I thought it was another standardized USB-C mode, but I did a deeper look into it and apparently, sort of.
VirtualLink uses custom cables/custom port wiring, which means that standard USB-C cables do not work with it. And if standard USB-C cables do not work, standard USB-C ports likely do not too. And that LG monitor does not seem to support VirtualLink either.
So, to OP: I was wrong with my previous post. It doesn't work that way. Use a DP or HDMI connector for the display and USB upstream port for connecting the display to the PC for USB connectivity.
