My aio has this very annoying grinding noise that just occured. I have the h80i v1 and is long past its warranty so i cant request an rma plus i bought it off of kijiji. it was running fine the past few months and all of a sudden it starts to make a grinding noise. i need help please
https://linustechtips.com/topic/1117984-aio-grinding-noise/
14 minutes ago, Genwyn said:
Pumps dead. Be glad it still pumps water presumably, usually when they die or the bearing fails or whatever they just stop pumping and then you slow roast your cpu.
Youre gonna need a new cooler. There really isn’t a fix for this besides basically rebuilding it with a new pump but that will cost more than a new cooler.
I suggest a BeQuiet pure rock or arctic freezer 34 for air, or a Corsair hydro H60 or cooler master master liquid 120L for a new 120mm AIO.
i just the pc upside down and it doesnt happen anymore. im unsure what the problem is
https://linustechtips.com/topic/1117984-aio-grinding-noise/#findComment-13001447
  • 1 month later...
I have two types of "grinding" noise on my H110, one is the one you are having, the second one sounds like scarping.
What I did to "fix" the problem you are having was plugging the pump power onto mb pwm vs just 12v power, not sure if this is the case for you but just a suggestion :)
https://linustechtips.com/topic/1117984-aio-grinding-noise/#findComment-13132975
Sounds like a grinding pump but if an air bubble makes it into the pump head where the spinny thing is it can make some funky noises (which isn't good). Might explain why tipping it upside made it stop (this moves the air bubble out). Verify CPU temps aren't spiking if it stopped making the noise it could be it completely died. The system will seem to work fine initially until the water heat soaks if the pump died.
Gaming - Ryzen 5800X3D | 64GB 3200mhz  MSI 6900 XT Mini-ITX SFF Build
Home Server (Unraid OS) - Ryzen 5950x | 128GB ECC 3200mhz |  EVGA 1060 6GB | 6TB SSD Cache [3x2TB] 66TB HDD [11x6TB]
https://linustechtips.com/topic/1117984-aio-grinding-noise/#findComment-13132983
What motherboard do you have?
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: G.Skill Aegis 2x16gb 3200 @3600mhz | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Red Devil RX 7900XT | Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: MP510 960gb and 860 Evo 500gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
https://linustechtips.com/topic/1117984-aio-grinding-noise/#findComment-13133123
