I just bought Corsair Void Pro Wireless RGB headphones and they don't fit very well.
I like everything about these headsets with 1 small issue.  Even at the smallest adjustment, they don't really fit.  They wobble if i move my head too quickly, the ear cups don't fit snugly, and if I look down, they almost fall off.
I'm thinking about returning them and getting the Logitech G533 wireless, but I'd like to know if there's anyone who has used both of these and can tell me if I can expect a better fit with the Logitech headphones.
Other than that, any ideas how I can modify these Corsair headphones to fit more snugly?  I was thinking about leaving them squished together a bit over night to see if i could tighten them up a bit.
Also considering the HyperX CloudFlight.  They are a lot more expensive, but it seems like they are going to be the lightest and most comfortable.
I also forgot to say, I am using these for gaming, some music and VR gaming.  Replacing my ancient wired Logitech G430, which are great overall, just not wireless.
Well Corsair is out of their league, stick to fans and hardware stuff not peripherals.  Logitech will be a much greater choice as you can see in my rig.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
yeah I also use the wireless ones, I find myself lifting them up a bit all the time. It's really annoying and I get how you feel.
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
Yes my G935 pownz.  Best gaming headset 7.1 and I don't care if someone says other wise as I have 2 Sennheiser HP's.  One for my studio work 500 dollars.  One for bluetooth and on the go noise cancelling.  The 500 dollar one has to be the most comfy HP's there is and it doesn't mess with your ears as their big just like the G935 not a small round cone and what not.  The positional audio on this thing is sick.  You hear people behind you beside you, up the corner and what not.  Truly amazing.  The mic is top notch as well.
As for audio quality, I am a audiophile for 22 years now and they sound excellent and are 50mm drivers.  The bass is top notch as well.
