Can my EVGA 500 BR, 80+ Bronze 500W, 3 Year Warranty, Power Supply 100- BR-0500-K1 100-BR-0500-K1 handle a rtx 2070 i78700k or should I upgrade
I’m planning on getting a 2070 and idk if my power supply is up for the job this is the current one I have EVGA 500 BR, 80+ Bronze 500W, 3 Year Warranty, Power Supply 100- BR-0500-K1 100-BR-0500-K1 should I upgrade or is it good enough?
Well, it doesn't seem to be a bad PSU - its only Bronze rated tho. You should be fine regarding the power draw.
ESL Profile: https://play.eslgaming.com/player/2432327/
F@H Profile: https://folding.extremeoverclocking.com/user_summary.php?s=&u=847206
Old System:        Current System :
i7-3770k + Cooler Master Hyper 212                           i9 9900k + Noctua NH-D15
Gigabyte Z77M-D3H                                                    Gigabyte Aorus Z390 Master
Evga Geforce GTX 970 SC                                          GIGABYTE GeForce RTX 2070 SUPER GAMING OC (F@H OC +70core/+580 mem)
HyperX FURY Red 16GB  DDR3 1600                        Corsair Vengeance  LPX 2x16GB DDR4 3200
bequiet PURE POWER 600W 80+ bronze                  Corsair RM 650x 80+ gold
Samsung 850 Evo 120 GB + 1TB HDD                       Samsung 970 Evo Plus 500GB
        Thermaltake Level 20 MT ARGB
it is pretty bad, the operating temp for high loads is like 30 Celsius which is basically room temperature. It would pair very poorly with high end hardware like this.
Primary PC:
Its a Bronze rated entry level PSU. Since he already has it, is it really that bad to keep it? Would it matter what his complete PC specs are?
3 minutes ago, Kenpachi1985 said:
Bronze rated
It's rating does not have nothing to do with the units quality.
Edited by noxdeouroboros
Anyone wanna recommend anything i am looking at this one EVGA 650 N1, 650W, 2 Year Warranty, Power Supply 100-N1-0650-L1 can that one handle better?
It literally does have to do with the quality. A lot of other things do too, obviously, but stating it like that is in my opinion simply wrong.
@Vyscis check this list for an overview. The PSU you just mentioned is rated to be dangerously bad (although there is a bit of controversy about rating lists for PSU's). Do NOT try to save cash on your PSU choice! *edit* i looked at ratings, f.e. on Amazon and people are reporting the mentioned PSU you asked about to be dead on arrival or simply frying and destroying their systems.
This one seems a little to good to be true but it’s on that list, BitFenix Formula 80 Plus Gold Standard ATX PSU 750W BF-750G, BP-FM750ULAG-7R
The formula gold is a famously overlooked PSU, it's cheap because the demand for it is so low (Bitfenix being a less known PSU brand) but the quality is excellent. 750 watts is a ton, you could get the 550 watt model and never have to worry. If it fits in your budget I highly recommend it.
Primary PC:
