Just bought a pre built PC as I know nothing about building PC's, it has a I9 9900K, Gigabyte z390 Aorus Ultra mobo and a H150i Pro AIO.
I noticed the CPU temps were hitting 80-87 degrees after about 3 hours of playing Modern Warfare 2019. is that high? to me it seems a little high.
Idle temps seem fine at around 35-40 degrees which is what my old PC sat at idle (i7 4790K, also i live in Australia so ambient cpu/room temp is a little higher than usual) and the AIO fans are at 100%
I HAVE NOT OC'D THE CPU. everything is default except XMP to get 3600mhz RAM which was done by the place I got the PC from.
only thing I seem to find online about this pairing of board and CPU with high temps is that the default settings push voltage a bit too extreme.
Would love to hear from the experience fol out there or people with this board.
No, it's fine.
F@H
GPD Win 2
probably too much voltage by default, i'd set a manual voltage.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
I’d say that’s kinda high, for gaming temps. Try to remount your AIO or get yourself some thermal paste and re-paste the cpu to see if that is the issue.
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
