Hey everyone. So lately something seems to be wrong with my pc. Works perfectly fine for couple hours(sometimes less) then randomly freezes, even while doing simple tasks, or browsing. first one screen turns off, on main screen mouse pointer disappears, and stays like that. Sometimes even for a minute and auto reboot after it. It started happening week or two ago and i cant seem to figure out whats wrong. My first thought was overheating, but thats no issue. Been monitoring and temps are way under normal. Did fresh windows instal and still same after it. Updated bios, all drivers are up to date. Any suggestions?  Desperate at this point since i play online games and especially fifa lately. And disconnecting is auto lose. Thanks in advance!
https://linustechtips.com/topic/1117401-please-help-idk-what-else-to-try/
Could you provide system specs?
could be a few things, i think may be the power supply (but also could be memory).
run a memory test if you can,
 https://www.howtogeek.com/260813/how-to-test-your-computers-ram-for-problems/
if you can swap out power supply, if memory test works. it be my second thing to try.
