Do power supply fan takes air inside the supply or blow it outside?
Solved by spartaman64,
is there holes on the case for the psu. if so you can choose to point it towards the case and it will suck air from outside or you can point it towards the motherboard and it will suck air from inside. sucking air from outside will have cooler air for the psu sucking air from the inside helps cool your case a little. its personal preference. if there are no holes for the psu on the case if you point it towards the case the psu will suffocate
