So i've been trying to overclock my 9900k and i've been seeing issues with the temperature getting really high even on stock settings and then it thermal throttles after a while. I've seen the VID hit at max about 210watts when looking in HWmonitor and after a while it thermal throttles and clocks down because the temps hit 100c and also all of these are on stock settings. I've reset and updated by bios multiple times and re-installed the cooler to rule out bad thermal paste application or bad settings.
Here are my Build Details: https://pcpartpicker.com/user/dariuslaser0/saved/4r2sZL
The 9900k is known for getting a bit hot, but with the cooler you have, you shouldn't have that much of a problem.
Check everything from scratch, thermal paste ect....
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
Check the mounting of your air cooler; you used adequate thermal paste, fans installed correctly ?
DRP4 should be more than fine in combination with you cpu. Not sure what other things it might be
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
