(TL:DR Below) I have a GTX 1070 ti, I had it installed with a ryzen 3600, and a asrock x570 motherboard (It has rgb, but I forgot which one it is) I had gotten a Noctua D15 cooler, which blocked the top pcie slot. Me, being stupid, tried installing the card there, despite the fact that it was touching the cooler. Luckily, the 1070 ti has a backplate, but after I had realised my mistake, I had some trouble demounting it. It took some struggle, but I managed. I put it in the second pcie slot, and I had plugged everything in when it gave me a black screen. The motherboard reported that it didn't have a GPU installed, and a pin is slightly scratched off the gpu. (Pics Below) but I had seen it had a scratched off pin after i had bought it, (ebay) and it worked before.
Edit: I'm using an rx 560 right now and it boots correctly in the bottom pcie slot.
TL:DR My GTX 1070 ti has a scratched off pin, and will not boot. Can I save it?
https://linustechtips.com/topic/1116716-gtx-1070-ti-blackscreen-issue/
