Can you specify your budget? I don't know what you consider cheap.
Personal Desktop":
Luna, the temporary Desktop:
define small! : ) I like to browse around geizhals with filters. Should help you.
https://geizhals.de/silentiumpc-signum-sg1-spc229-a1999127.html?hloc=de
Just set filters like hight up till 45cm, depth till 45cm and so on.
Life is really challenging. I don't always suceed: )
It's a full atx motherboard, the case won't be small.
google "slim atx case"
Cougar MX330 has a solid side panel, option and should be around 35 euros, dollars and pounds
