Need feedback on whether to improve some things or problem i will encounter while buliding
Solid build you got there! I love the SG13, just built a system in that case myself. It's a slightly more advanced case to build in because it is so compact and hard to cable manage in but you should be just fine! I would remove the HDD tray at the top front, as you do not need it and it will be in the way. Gives room to stuff cables away. Good luck!
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
Thank you!
My only concern is that as a newbie, is that what are my upgrade options with this build
backstory: i travel a lot and i need a build that i can pack in my suitcase and game anywhere!
Just now, Derrk said:
looks like a fun build. only recommendation i can think of is to get a better fan than the one that comes with the H60. id suggest a noctua nf-f12 or corsair ml12
Corsair ML all the way!
My Builds:
MEGA Desk Build
4 minutes ago, SpecialK90 said:
Thank you!
Upgrade options are limited due to hardware size. But new CPU and GPU down the road is perfect. Just can't fit big hardware in. I wiill finish my build log right away and link it so you can see what I did.
My Builds:
MEGA Desk Build
Thank you!
17 minutes ago, SpecialK90 said:
Thank you!
Never mind a proper build log will take me to long.
Here is my build and insight I can provide:
Case: Start by removing all panels. you will need to leave the PSU shroud/support bracket.
Cooler: I see you went with a 120mm AIO, good choice. The stock cooler won't fit anyways. if you change up your PSU and go SFX you can go push/pull with a 120mm AIO (what I did). Or if you just get a small/mini GPU you can get a 140mm AIO. With your config your cooler is perfect, anything more/bigger will not work.
GPU: limited to dual slot twin fan cards or mini cards, nothing else will work or fit.
PSU: This is the only thing you may want to change. Reasoning for going SFX is to allow more room for a second AIO fan and it allows for more room to cable manage as well as a admittedly janky, but helpful 80mm exhaust fan. Otherwise this case only vents passively, you can turn your PSU the other way around to draw air out but then you are keeping your PSU under high operating temps, not ideal. I just held this fan in place with twist ties, it is perfectly fine and helps pull hot air out of the case. If you go SFX the cost is higher and you may need and SFX to ATX PSU shroud but its something to consider. 20190411_163444.thumb.jpg.cc47ebfbdddf285621d9be43c26a17be.jpg
Lastly if you care about dust consider getting some magnetic fine dust filters. Other than that expect a mess of wires but otherwise is fairly straight forward.
And a few more pics:
20190411_163357.thumb.jpg.52e77419361a905922cf93fdb412f6f0.jpg20190411_164936.thumb.jpg.2609258344199105609ddfcd69562c9c.jpg
My Builds:
MEGA Desk Build
Thank you very much, this will definitely help me when I'm building it.
I'll be buying the parts during cyber Monday and build during Christmas break.
Hope I can reach out to you if I need input on certain things.
Thank you once again
So overall what would you recommend I replace what with what
My only recommendation is maybe get an SFX PSU instead so you have more room to ad a second AIO 120mm fan, and ad a 80mm exhaust fan. In my system I got the Corsair SF 450 gold and had to buy an SFX to ATX bracket separately.
No problem, you can message me!
My Builds:
MEGA Desk Build
I think I’ll take your recommendation.
will you be doing a proper build log? because that will really help me since it’s gonna be a similar build....I haven’t built a pc ever and so super nervous that I will mess something up!
Yeah I am planning on doing a build log, if I do I will link it to you
My Builds:
MEGA Desk Build
