I am trying to clean my 256gb SSD to a 500gb SSD as an upgrade. I have attempted to close several times and every single time I get boot device is not accessible. I have tried the bootrec commands and the /fixboot has the access denied. both of the hard drives are formatted in MBR and I have tried to fix the boot on the hard drive several times. when I would normally clone the system reserved partition would have a drive letter. I would get rid of the drive letter and then re letter the windows partition. I honestly don't know what I'm doing wrong with this point. if anybody can offer me some advice or maybe a really in-depth video on how to fix this problem I would really appreciate it.
https://linustechtips.com/topic/1115879-i-am-trying-so-hard-to-clone-my-drive/
"Black Out"
Dedicated Streaming Rig
You should clone all the disk part including the system reserved partition.
What program you used for cloning?
ive tried clonzilla bootable several times and macrium reflect with both usb into another pc
I have check every partition and it gives me inaccessible. I got one last-ditch effort that I was going to try myself and that is to install Windows on the drive I'm trying to be the windows partition from my drive to that drive
