I’m planning to upgrade from gtx 1060 3gb to rtx 2060 6 gb gpu.
my pc specs are-
ram-2400 DDR4 16gb
cpu-i5 8400
display-1080 60 hz
psu-400 watts
will this be a good upgrade in terms of getting better fps and overall gaming performance.
also will the upgrade cause any sort of bottlenecking ?
https://linustechtips.com/topic/1115852-is-i5-8400-compatible-with-rtx-2060/
You should get the RX 5700 at the same price, it has closer to 2070 performance with a bit of work, just don't overclock it, maybe undervolt it a bit.
Your CPU is fine for like 100hz gaming, Is that a pre-built PC? they usually have pretty low end PSUs.
Also either are overkill for your 1080p 60hz display, should maybe upgrade that first, or just soon after getting a faster GPU
Also the RX 5500/5600 is coming soon ish, and you should be able to get that with a 1080p 144hz display at least. or a used 4k 60hz display
2 minutes ago, Awesomeguy900 said:
Just so you know, You also get ray tracing on some games. If you have the budget, i would say to push a little bit more but overall its good for Fps boost etc, what games do you plan on playing?
Ray tracing is still a gimmick, there are very few games that support it and it basically kicks your FPS count to the kerb once you fire up the ray tracing
On a RTX2080, maybe, turning on ray tracing on a 2060? I don't think so.
CPU: AMD Ryzen 5 3600  Heatsink: ID-Cooling Frostflow X GPU: Zotac GTX 1060 Mini 6GB RAM: KLEVV Bolt 3600Mhz (2x8GB) Mobo: ASUS B550-F ROG Strix (Wifi)  Case: Fractal Design Meshify C PSU: Deepcool DQ-M-V2L
8400 will be a very small bottleneck on some ubisoft games, otherwise ur ok, i'd look at the 2060 super or if you don't need ray tracing, the 5700 xt red devil.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
My psu came in pre installed in the cpu case
case -
Cooler Master CMP 500
Psu-  t600
3 minutes ago, Dandapani108 said:
Psu-  t600
nevermind that...
I would suggest just waiting to see what the RX 5500/5600 offers soon enough, it would be better to have a 1080p 144hz display with a slight GPU upgrade.
Unless you can upgrade your display soon after buying the RX 5700, which is on sale at times for $289 if you're in the US.
I mostly play RPGs,
witcher3, ac odyssey, nfs, battlefield...
11 minutes ago, Dandapani108 said:
My psu came in pre installed in the case
Cooler Master CMP 500 , t600 400watt psu
1 minute ago, Tan3l6 said:
He has an unbranded PSU
But if it works, not an issue I guess.
t600 brings up this thing
https://www.gotheone.com/gaming/aigo-g-t600-psu-full-modular-80-plus-bronze-600w-power-supply-unit
Yep, found that too. To be honest - never heard of such PSU manufacturer (brand) before. The positive - looks like a modern PSU outside. Modular cables and all.
Bad - no thorough reviews.
Just some info in the LTT forums -
Not saying it's definitely bad, just unknown.
What's this useful for?
I remember when I upgraded from a RX380 to an RX580 on an i7 920 at 3.8 and saw a noticable FPS improvement.
Since then I have been sceptical about bottlenecks regarding relatively recent components.
Sure I had one but I got the FPS bump I needed so what mattered?
i5 8600 - RX 6600 - Fractal Nano S - 1080p 144Hz
I mostly play RPGs,
my pc specs are-
ram-2400 DDR4 16gb
cpu-i5 8400
display-1080 60 hz
psu-400 watts
clearly you can.
honestly stop lying. any rtx card can do ray tracing. if it doesnt do it on ultra they can do it with some tweaked settings. yeah it would be better on a 2070 super and up. but a 2060 is possible to play it on!
and another one. put overal settings on high and rtx on ultra and voila 60 fps.
granted its a shooter. but is it playable? YES.
PC:
MSI B450 gaming pro carbon ac              (motherboard)      |    (Gpu)             Powercolor RX 9070XT Red Devil
ryzen 7 5800X3D                                          (cpu)                |    (Monitor)        2560x1440 165hz (phillips 27m1c5500v)
Arctic Liquid Freezer II 240 A-RGB           (cpu cooler)         |     (Psu)             seasonic focus plus gold 850w
Cooler Master MasterBox MB511 RGB    (PCcase)              |    (Memory)       Kingston Fury Beast 32GB (16x2) DDR4 @ 3.600MHz
Steel series apex pro                       (keyboard)            |    (mouse)         Razer Basilisk v3 pro
I think i will go for rtx 2060 super although i am going to need a 500/600 watt psu.
i will switch to a 1080i 144 hz later down the line.
you could go with the rtx 2060 super. if you like graphics and dont mind seeing the newest stuff go for it. but do change the psu if you want to indeed go for that one. your current one should do a 2060 and your cpu without an issue. you wont see bottlenecks orso.
PC:
if you're just going with that then the RX 5700 is faster at the same price
^^ Yeah. Unless you need the RT features and better NVENC encoder from the 2060, the 5700 is an excellent option.
550W is pretty standard, but you likely don't need that for a 2060. Peak power (highest spike) is only 167W or so: https://www.tomshardware.com/reviews/nvidia-geforce-rtx-2060-ray-tracing-turing,5960-8.html. 8400 pulls a max of about 118W: https://www.tomshardware.com/reviews/intel-coffee-lake-core-i5-8400-cpu,5281-10.html. On a 550W PSU that'd leave 265W for your drives, mobo, and case fans. Could easily go with a solid 450W if they're cheaper (550s are often the same price or sometimes less). Also the RX 5700 pulls up to around 203W (https://www.tomshardware.com/reviews/amd-radeon-rx_5700-rx_5700_xt,6216-4.html), still easily handled by a 550 or even a 450. Also keep in mind these are torture test numbers, in games power consumption is often lower.
Main PC
CPU: i5 12600KF
Cooler: Noctua NH-L12S
Motherboard: ASRock Z690 ITX/ax
RAM: 2x16GB 3600Mhz DDR4
GPU: Intel ARC A770 16GB LE
Storage: 1TB MP34 + 2TB P41 + 2x 1TB MX500
ODD: LG WH14NS40
PSU: EVGA 850W GM
Case: Silverstone Sugo 14
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 15" M3 MacBook Air (work) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, flash, running Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2022 Kawasaki KLR650
Yes it is compatible, no it will not bottleneck your RTX2060. Yes its a good choice. If you're feeling brave, you can also consider 980ti's in SLI from eBay. But I can see why people wouldn't want to do that. It requires quite a bit of knowledge to pull off, but you basically get 2080ti performance for 400$ in most games with a little technical skill. Built not bought as they say.
Also to the poster above that said the 8400 is only good for 100hz gaming. I guess I'm constantly hallucinating when I operate my pc then, because in all of the games I play I average 200+ fps on my 240hz monitor, and I'm currently using an 8400 in my gaming pc. The 8400 / 9400F is the every-mans gaming CPU, don't let these people dissuade you. The 2060 is a good card as well.
Entertainment PC ~ 9900k - 32gb Ripjaws V CL16 - Aorus Pro Wifi - DRP4 - 240GB Intel SSD - 6TB Conventional HD's - Corsair RM850x - Fractal Mesify C in White - EVGA GTX 980Ti SC
Displays ~ Lenovo g34w-10 (Main) - BenQ XL2540 (Gaming) - 32" Acer ET322QR (For Laptop) - BenQ XL2411 (Backup / In storage) - Vivo STAND-V001JB & STAND-V001T
Peripherals ~ Corsair K68 RGB MX Red - BFO9000 (in progress) - Logitech G900 - Blue Snowball - Bose QC 35 II
Laptop ~ Asus a17 4800H / 16GB / 1TB NVME / 1660Ti / 120hz w/
Second PC ~ i5 8400 / 16GB Ripjaws V CL18 / MSI z370 A-Pro
Productivity Other ~ Macbook Air 2015 model - Macbook Pro 17" (2011) - iPad Pro 2015 Model w/ Pencil w/ Otterbox Hardcase - Toshiba Satellite S50-D
Networking ~ Fk off
Bio - Literal Retarded Autist
I think both cards are good as per the benchmarks in the below link.
https://gpu.userbenchmark.com/Compare/Nvidia-RTX-2060S-Super-vs-AMD-RX-5700-XT/4049vs4045
will probably buy the one which is cheaper..
What about my motherboard?
will B360 Pro Vdh be still good with the new gpu?
