These are my specs:
Processor: AMD Ryzen 5 1600
Graphics Card: MSI Armor RX 570 4gb
Motherboard: MSI b450m pro m2 v2
RAM: Hyperx 2x4gb 2666mhz
PSU: Gigabyte 700w 80+ bronze
SSD: Kingston A400 SSD - 240GB
I'm having troubles with the video output. If I turn on the PC with the HDMI connected to a TV from my RX570, I get no signal and the VGA led of my motherboard turns on.
If I turn on the PC without connecting the HDMI cable, the motherboard LEDs turns on and off, and the PC boots to windows normally. Then I can plug the HDMI cable and everything works properly (I did a lot of tests and benchmark an everything seems ok). If I try to start the BIOS pressing the del key without the HDMI connected (and then plugging in the cable), I get no signal.
I test an old GTX 960 with this motherboard, and it worked correctly, I can enter the BIOS. I even used it to flash the latest BIOS, but the problems with the RX570 persist.
Also, I test the RX570 in my old PC, and boots normally, even to the BIOS.
I tried clearing the cmos removing the motherboard battery, also booting with a single stick of ram, but it doesn't fix the issue.
https://linustechtips.com/topic/1115507-vga-led-on-and-no-video-output/
I had a similar experience with my current build,
It turned out my new GPU is very picky about display cables,good thing i have dozens of HDMI cables.
With some cables i had no signal,with other cables the signal was lost in the middle of using the PC,
Until i found a cable that my GPU "liked",and it's fine ever since...
Probably most of my cheap cables are out of spec.
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE GTX 1660 GAMING OC @ Core 2085MHz Memory 5000MHz
Cinebench R23: 15669cb | Unigine Superposition 1080p Extreme: 3566
Maybe it's the cable, but I tried the GPU in another PC with the same cable, and the PC booted without problems
