Hi Guys,
After Spending week,Finding Budget Earbuds which can Deliver Good Sound,
(Skip to Second Paragraph if you want main Part of Question XD )
SO i been using Audio Technica A50x on my phone for listening Music, but i want to Get Rid of Over the ear headphones,
First Reason is,First Most Important Reason is, I Cant Sleep While Listening Music,i cant Change my Position to Left Side, if i do,i get pressure on left ear and Sound get Imbalanced
and Second Reason is i cant do Workout in Gym Properly and it Feels ODD for sure..
Ive been Searching for Good Earbuds from amazon.in (indian)
there are HUGE List, many many Brands.
first think i need to tell you, if in amazon uk or us, earbud price is 30$ then in india it will cost 120$,
everything costly in india especially Tech,
im so much confused Right now, What i did is, i purchased 5 Earbuds from my credit card, each costs 70$
i thought i will try all of them and will return other 4 and keep one of them,
but 4 of them got delayed so i canceled them.
So Please Help me to find Good Wireless
earbuds, which Sounds Good, i dont want brand because it just costs and starts from 300$ in india and there are high chance of fake product.
7 minutes ago, Boochik said:
Thanks for giving your costly time, i actually need wireless earbuds..
you cou replace the stock cables with bluetooth mmcx or QDC cables otr plug them into a device like the fiio ubtr
I think your right but it will make my budget too high, im not that rich guy, i can spend like 100$ maximum. :((
17 hours ago, Boochik said:
And what wireless Bluetooth earbuds you would suggest?
none that are under a $150 thats why I suggested you make your own with what I linked
