Masterfan ARGB 120mm
Go to solution Solved by ZephCloud,
11 hours ago, Nnes said:
I am using a MSI b450 mortar max but it only has Jrgb spots and no argb
Ok..the conclusion is you can still uses the fans..and control fan speed in bios...
Because the motherboard doesn't have JRAINBOW connectors you can't control the argb lightings by software..you can still use the cooler master controller buttons to set the different lighting effects..
it's magnetic...lol..I just leave them on the psu and drive bay..the window for the living room pc is small so the cables aren't arranged..hahaha
  • CPU
    AMD Ryzen™ 7 5800X 4.7Ghz
  • Motherboard
    MSI MEG X570 ACE
  • RAM
    G.SKILL Trident Z Royal Series 32GB (2 x 16GB) F4-3200C16D-32GTRS
  • GPU
    GeForce RTX™ 3060 EAGLE OC 12G (rev. 2.0)
  • Case
    Cooler Master MASTERBOX MB520 ARGB + Cooler Master MasterFan MF120R ARGB
  • Storage
    ADATA XPG SX8100 2TB PCIe Gen3x4 M.2 2280 SSD
    ADATA LEGEND 960 4TB PCIe Gen4x4 M.2 2280 SSD
    ADATA Ultimate SU800 2TB 2.5" SSD
    Crucial BX500 2TB 3D NAND SATA 2.5-inch SSD
    Toshiba X300 4TB 7200 RPM
    TOSHIBA MG06 (MG06ACA10TE) 10TB 3.5 Inch 7200RPM Enterprise SATA Hard Drive
  • PSU
    Cooler Master MWE GOLD 750 FULL MODULAR
  • Display(s)
    Acer KG271B Gaming Monitor (HDR Ready 27" 1920X1080 240Hz)
    MSI PRO MP241
  • Cooling
    Cooler Master MASTERLIQUID ML240R RGB
  • Keyboard
    MSI Vigor GK80 RED GAMING KEYBOARD
  • Mouse
    Razer Naga Hex Wraith Red Edition Wired Laser Mouse
  • Operating System
    Windows 11 Home
  • Router
    tp-link EB810v BE22000 Tri-Band Wi-Fi 7 VoIP Router
    Asus ROG Rapture GT-AX 11000
  • Network Card
    tp-link Archer TBE550E BE9300 Wi-Fi 7 Bluetooth 5.4 PCIe Adapter
https://linustechtips.com/topic/1115282-masterfan-argb-120mm/#findComment-12979860
I mean that there isnt a argb header on my mb there are only jrgb once wich are with 4 pins and the one that comes with the fans is with 2pins empty spot and 1 more pin. I was wondering is there any way that ill be abel to use them or do i have to look for other fans.
https://linustechtips.com/topic/1115282-masterfan-argb-120mm/#findComment-12980422
What motherboard are you using?
Anyway..you can still connect all other cables and it'll still work..just that you can't control the fan's argb with software...I was using them in my older pc which doesn't have any header other then normal fan headers before...
You can still control the fan speed in bios..as for the colour you'll have to use the controller...
  • CPU
  • Motherboard
    MSI MEG X570 ACE
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    MSI PRO MP241
  • Cooling
  • Keyboard
  • Mouse
  • Operating System
    Windows 11 Home
  • Router
  • Network Card
https://linustechtips.com/topic/1115282-masterfan-argb-120mm/#findComment-12981183
https://linustechtips.com/topic/1115282-masterfan-argb-120mm/#findComment-12982259
  • CPU
  • Motherboard
    MSI MEG X570 ACE
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    MSI PRO MP241
  • Cooling
  • Keyboard
  • Mouse
  • Operating System
    Windows 11 Home
  • Router
  • Network Card
https://linustechtips.com/topic/1115282-masterfan-argb-120mm/#findComment-12983641
Thnx for mentioning the controler thing last night found out that has i/o button pushed it and voala it worked. Thanks for the help :)
https://linustechtips.com/topic/1115282-masterfan-argb-120mm/#findComment-12983814
you're welcome..i happened to have the same fans...haha
  • CPU
  • Motherboard
    MSI MEG X570 ACE
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    MSI PRO MP241
  • Cooling
  • Keyboard
  • Mouse
  • Operating System
    Windows 11 Home
  • Router
  • Network Card
https://linustechtips.com/topic/1115282-masterfan-argb-120mm/#findComment-12983822
