Hello guys, my system at stock is unstable and crash on Aida64 stability test. I can pass Prime95, OCCT, Asus Realbench, Memtes86, BF5 and BF1 games, but I will crash in Aida64 either RAM XMP is on or off. Is this Aida64 bug or there's something wrong with my system? I already swapped out the mobo with a brand new, and my ram is on mobo QVL. Any help and suggest would be appreciate because I need help.
r7 3700x
ASUS ROG X470F
CORSAIR VENGEANCE RGB PRO 32GB (4x8GB) DDR4 3200MHz C16 LED Desktop Memory - Black https://www.amazon.com/CORSAIR-Vengeance-3200MHz-Desktop-Memory/dp/B07D1XJH2W/ref=sr_1_4?crid=3Q93TOUJXDL3W&keywords=corsair%2Bddr4%2B3200&qid=1571495390&sprefix=corsair%2Bddr4%2B32%2Caps%2C200&sr=8-4&th=1
Sapphire Pulse RX 590
EVGA G1+ 650W psu
https://linustechtips.com/topic/1115276-system-unstable-on-aida64/
16 minutes ago, OlympicAssEater said:
Prime95
When you test prime95, which test are you using and do you have AVX enabled or disabled? Aida64, as far as I know, uses AVX, while Memtest86, BF5, BF1 etc. don't, so that could be the cause of your crashes.
Prime95 v29.8 build 6 with default options. Even Aida64 with cpu and fpu check run, my system will crash. Latest bios with 1.0.0.3 abba.
71115538_Annotation2019-10-19230304.jpg.2c48c01618f7042d0d00ffa61b5c8b08.jpg472971846_Annotation2019-10-19230406.jpg.f05322861e7f85ed1055a4f4e9fcca3d.jpg242919374_Annotation2019-10-19230426.jpg.9126c7d9baae7c4aee5efb12052df870.jpg
