I just wanted to ask if i've picked some proper parts for my new rig (Some things i would love to upgrade but didn't/don't have the money for) Also want to list that i am upgrading because my current pc is getting slow. I also plan to run (1) 240 Hz (2) 144 Hz monitors.
Aim is streaming, gaming and content creating.
Edited by Bizzare
Forgot to list a bunch of stuff
https://linustechtips.com/topic/1115184-pc-parts-for-new-build/
drop to 550W. tbh since the second is 144Hz. the 240hz will be capped at 144hz.
and go with 3600 and b450 tomahawk. you're streaming and editing. it does needs a bunch of cores to work with.
  Spec: Macbook Air 2017
ProcessorPU: ii5 (I5-5350U |
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
 | GPU: Intel HD 6000 |
| Audio: JBL 450BT Wireless Headset |
https://linustechtips.com/topic/1115184-pc-parts-for-new-build/#findComment-12979227
How come the 240hz will be capped at 144hz?
https://linustechtips.com/topic/1115184-pc-parts-for-new-build/#findComment-12979262
the second one is 144hz. in my knowledge both monitor needs to run at same rate
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
https://linustechtips.com/topic/1115184-pc-parts-for-new-build/#findComment-12979606
