Needing a Budget E-ATX Case With At Least One 5.25" Bay *Help!*
Go to solution Solved by PianoPlayer88Key,
You need to be careful looking for "EATX" cases to fit a 13" wide motherboard like that  A lot of "EATX" cases will only accept boards up to about 10.7" wide or so (like some higher-end single-socket enthusiast boards), and thus are IMO incorrectly labeled as EATX compatible.
For example, I believe the Corsair 750D that @Masman8675 suggested would NOT fit the X8DTH-6F.  (Also I personally would not recommend a product that would require potentially-warranty-voiding modifications to work with another product, but maybe that's just me.)
True EATX is 13" wide, which is the same size as SSI EEB.  The 10.*" boards (and cases compatible with them) should, I think, be labeled something like "ATX+".  (BTW, SSI CEB is 10.5", similar to the ATX+ enthusiast boards I mentioned.)
Anyway, here's a USA-based (cause I don't see your location / country in your profile) pcpartpicker list, filtered to show cases with at least 1x 5.25" bay, compatible with SSI EEB, and filtering out ones without prices.
https://pcpartpicker.com/products/case/#G=1,12&sort=price&xcx=0&f=14&X=100,315006
The cheapest one I see is the $100 Rosewill Rise.  The Phanteks Enthoo Pro TG is $4 more, and if I was looking for a case like that, it's probably the one I would be more likely to get.
So, I'm in the middle of getting a new dual Xeon rig up and running, but am having issues finding a good case for my motherboard (SuperMicro X8DTH-6F).  Ideally I only want to pay $100-200 for it not $400 like retailers seem to want.  Only real requirements are that it has at least one 5.25" optical drive bay, and is EATX of course. ?
Does not have to be new, though bonus points for a window on the side lol.
Thanks in advance!
Why does it have to have a 5.25" drive bay?
Those are pretty non-existant on modern cases.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
Oh, thank you very much!  I was a bit skeptical on some “E-ATX” model cases really fitting it.  I had an EVGA board that had triple channel RAM and was classified as an E-ATX mobo.  Needless to say it was quite small in comparison to the SuperMicro lol. You have helped me greatly, likely saving me a headache or two.  Thanks!
  • 2 months later...
Went with the Enthoo Pro.  I had ordered the RISE first, as it was on sale, but then found out there’s only 3 HDD bays so returned it.  The Enthoo is so much nicer, cable management is a dream, there’s tons of HDD bays, more 5.25’s, build quality is quite a bit better, and much better fan/rad mounting options.
  • 2 weeks later...
Awesome! :D next, post the obligatory pics of the setup? :D (can do it in another thread - I think there's a show off your setup thread somewhere.)
So I shall.  Stay tuned. ;)
