All the part picking, slapping it together, and troubleshooting paid off!
I'm on first gaming PC. ❤️
Any recommendations on antivirus software or useful tools to help protect this baby?
I haven't messed with any video card settings. Where can I tweak them if needed?
https://linustechtips.com/topic/1115118-first-build-up-need-antivirus/
you click random shit and dont use a good adblocker? hm
bitdefender is the best?
panda cloud free?
those two?
idk I never used an antivirus
If I had one wish, I would ask for a big enough ass for the whole world to kiss
If you're tech savvy, all you need is CommonSense™ and a good ablocker, such as uBlock Origin by Raymond Hill aka gorhill on GitHub. If you're not as tech savvy, like to download random stuff from random sites, or just want better heuristic-based protection, buy the paid-for Malwarebytes Premium. Bam. Done.
Desktop: KiRaShi-Intel-2022 (i5-12600K, RTX2060) Mobile: OnePlus 5T | [REDACTED] - 50GB US + CAN Data $34/month
Laptop: Lenovo Yoga 7i (16") 82UF0015US (i7-12700H, 16GB/2TB RAM/SSD, A370M GPU) Tablet: Lenovo Tab Plus (256GB)
Camera: Canon M6 Mark II | Canon Rebel T1i (500D) | Canon SX280 Music: Spotify Premium (CIRCA '08)
I use Pie-hole for ad blocker, and anything like torrenting or testing of software im unsure of is done in a VM machine if all goes will then I will install on the actual machine. Windows Defender tends to tick most of the boxes.
Internet Connection
My Rig: AMD Ryzen 9 3900X @ 4.3Ghz | Asus Prime X470-Pro | Corsair Vengeance RGB Pro 32 GB (4 x 8GB) DDR-4 3000Mhz OC'd @ 3400Mhz 16-20-20-38 |
EVGA RTX 2070 8GB XC Gaming OC @ 2145Mhz Boosted/ 1925Mhz Memory | WD SN750 500GB M.2 NVME | Gigabye 240GB SSD |
XSPC EX 360mm | Corsair XC7 RGB CPU WB | EK-Vector RTX 2080 | Alphacool Eisbecher D5 150mm Plexi | XSPC Fittings | XSPC FLX Clear 7/16" ID, 5/8" OD |
Corsair LL120 x6 | Corsair RM750x White 2018 | Corsair Commander Pro | Corsair Obsidian 500D RGB SE | Corsair RGB LED Lighting PRO Expansion |
Corsair Strafe RGB MK.2 | Corsair Ironclaw RGB Wireless 18,000DPI | Acer 32" 4K 60Hz HDR600 Cert. ET322QK CBMIIPZX |
Passmark Score
3dmark Score
PC Parts Picker Link to Build
Network
Netgear LBR20 LTE Router | Verizon Unlimited Prepaid Hotspot Plan
HP 2530-48G-PoEP Switch
Rasberry Pi 4 Running Pihole
Linksys Velop 3 Mesh Wifi AP's
