Help please possible mobo fault?
Go to solution Solved by ManosMax13,
I think the "Game on rog strix" isnt supposed to flash at all. I think I have the same motherboard just the b350 version.
Hello everyone, This is my first ever build.
The parts, Please can you tell me if i'm going crazy? The top left corner of the motherboard lights up different colours and i can edit these effects. Is this supposed to happen / sync in the middle section too? Where is says "Game on rog strix"? I'm confused. You can see what I mean if you zoom in on picture 2 :)
https://imgur.com/hakf5v0
https://imgur.com/OOYpVH3
AMD Ryzen 2600 Stock settings
ASUS ROG STRIX B450-F
Asus GTX 1060 3GB
Corsair LPX 32 GB (4 x 8 GB) DDR4 @ 2933 MHz D.O.C.P enabled
Corsair MP510 240GB NVMe
Kingston 240GB SSD
Seagate 1TB HDD
EVGA SuperNOVA 750 G+
Corsair Carbide 275R Tempered Glass
BenQ XL2411 144Hz
Cooler Master 120 Lite
Logitech G403 HERO
Corsair VOID PRO RGB USB Dolby 7.1
Corsair K55 RGB
SteelSeries QcK
https://linustechtips.com/topic/1115024-help-please-possible-mobo-fault/
