Hey guys,
I received this laptop on Christmas as well as my brother who got the same one. (They're both refurbished from ASUS I believe)
His is still running like brand new and mine is running really slow, I've tried resetting it and its still lagging like hell.
We both have a GTX 1050ti, Windows 10 64bit, 1tb storage HDD
Please help
https://linustechtips.com/topic/1114887-gtx-1050ti-stuttering-and-fps-drops/
Just now, Uptivuptiz said:
What games?
What are the rest of the specs of the system?
Everything basically, for example he can run Fortnite at a solid 60 frames whereas I only can get 15-20 FPS even with nothing open in background.
Processor    Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz, 2808 Mhz, 4 Core(s), 8 Logical Processor(s)
GeForce GTX 1050 Ti, NVIDIA compatible
C Drive: 237.66 GB (255,181,848,576 bytes)
D Drive: 931.51 GB (1,000,203,087,872 bytes)
I forgot to ask what resolution you play at and are the 2 systems identical?
But you can try reinstalling Nvidia drivers to see if that helps.
Please mention or quote me if you want a response. :)
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
1920:1080 and yeah they are identical.
I've reinstalled them aswell :|
Did you run DDU when reinstalling?
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
What's that?
Display Driver Uninstaller (DDU) is a program that completely uninstalls the graphics driver to make sure that no errors will occur after a reinstall.
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
Already i've done it, I guess I go and install the NVIDIA drivers from their site now yeah?
could be faulty ram,  or a simple thing such as power saving modes,  try set ur gpu to maximum performance in the driver @ 3d settings in nvidia
also windows power plan to high performance, if that doesnt solve it can also be HPET settings
if they have been refurbished im more towards the faulty ram part tho, i had a laptop once with faulty ram on arrival, it was slow at times and stutter and bsods randomly,  figured it was the ram,  got new laptop same model and it was much quicker instantly also and no more stutter ( in my case it was faulty ram )
tho if u dont get any bsods , its possible u just have software problems
Yes, just install it like you normally would.
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
Power saving modes dont do anything for me which sucks.
It could be faulty ram but not sure, Would want to know for certain before I go spending money on stuff.
I'll take a look at the HPET guide
Doesnt look
Looks like I don't have HPET so its not that :\\
Also
I don't get BSOD so what should I do now?
Edited by Emerald108
5 minutes ago, Emerald108 said:
Doesnt look
Also
every system has hpet , its just software or hardware driven, if u dont have it in the bios u need to disable it in windows
coz by default its turned on\
try the power management stuff, or temp monitor, maybe ur system is throttling
faulty ram is still a factor i would run a prime95 blend for atleast 12hours to make sure its stable
I tried disabling it in windows but got this
C:\WINDOWS\system32>bcdedit /deletevalue useplatformclock
An error occurred while attempting to delete the specified data element.
Element not found.
I'll check BIOS anyways and see, I'll do a prime95 test and see aswell
Element not found.
run as administrator cmd and dont go to any folder just press bcdedit /deletevalue useplatformclock, without administrator it wont work
Yeah I did that in admin and it came up with that error
