My PC does not run at home
Go to solution Solved by Crazy Freak,
1 hour ago, Palden said:
Well, first off, the first video you posted shows you tried booting without RAM in. The PC will never POST without ram. Second, make sure that you use the correct RAM slot on your mobo if you're going to use only 1 ram stick.
The video might be so but I have done booting even with RAM...just brought an electrician to home....changed some wiring in the home....bingo...PC runs
Thanks for the help guys
Hi guys,
This looks weird but I don't know what is wrong with my new assembled PC.It turns on and I can use it perfectly well in the shop.However,when I come to home,the PC does not turn on.I can only see my motherboard LED lights on..
Kindly help me to solve this problem
https://linustechtips.com/topic/1114663-my-pc-does-not-run-at-home/
4 minutes ago, Srikar Malyala said:
Hi guys,
Have you tried other wall sockets at your house?  If nothing else changes that's the first place I would look.  Are you also sure you haven't unseated something during transportation?
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
I have tried each and every socket in my home.All the cables and connections to the PC are intact and transportation is done by me very carefully as I have it in my laps while carrying.I am suffering from this problem since four days.The PC wont turn on
Where do you live?  I only ask because Im curious if the power delivery in your Country may be faulty(dirty)?  Would a UPS fix this if that's the case?
I live in Hyderabad,India.I use a UPS (1000VA/600W) which does not help me.
The weirdest thing is all the household appliances like microwave oven,AC,refridgerator work very well and they consume more power than the PC
The weirdest thing is all the household appliances like microwave oven,AC,refridgerator work very well and they consume more power than the PC.
Specifications of my PC rig
Ryzen 7 2700x
Asus x470 prime pro
650 w psu (corsair vs650)
500 GB hdd
250 GB ssd
1* m.2 ssd (120 GB)
1*16 GB ddr4 ram
NVIDIA GTX 1060
How many times has this occurred?  Is this new (the issue, as in this is the first occurrence or has this occurred daily for a few days)?  Could you have possibly disconnected the Start Button pins during transportation?
If I were to have this problem I would take the PSU out, and jumper it.  That way I can find out if the PSU works without being hooked up to anything but the wall socket.
Depending on what happens I would drive to the shop and try it there (if it didn't kick on at home).  If the PSU kicked on at home I advise you to google "breadboarding a PC" and continue building the PC that way at home until you run into another snag.
This is my first time encountering this problem.
The PSU runs without anything connected to it except the power cord.However when I just connect it to motherboard and CPU ...it does n't run.
The guy at shop did not even open the case of PC and plugged in the cord(had this experience three times )...then bingo....PC runs
1 minute ago, Srikar Malyala said:
The PSU runs without anything connected to it except the power supply.However when I just connect it to motherboard and CPU ...it does n't run
Is your motherboard solder points or the case standoffs themselves coming into contact with the motherboard or case (I.E. a solder point on the mobo touching the metal standoff, or an extra metal standoff on the case in the mobo tray you didn't remove touching the mobo causing it to short - I.E. PSUs now-a-days wont even begin to try to turn on).
Google "breadboarding a PC" and follow the directions to a T.  Build it 1 component at a time as it tells you so that you can start to eliminate possibilities.
Right now Im leaning towards an extra case motherboard standoff that is making contact to the motherboard and however you position it at home, or during transport, its just not touching at the Shop.
At least that's what I would do (breadboard)
Don't have the mobo speaker...will update the status tomorrow as I cant get it now (23:33 here)
Understandable - sucks your going through this
2 hours ago, TechyBen said:
Did you take your mouse and keyboard with you, or did the repair shop use their own?
If a pin is bent on the mouse/keyboard usb socket, then it will stop the pc booting, as it detects a "ground".
The PC shop used their own mouse n keyboard...the pins are not bent...I checked them carefully..the PC doesn't run without external devices connected
Bad wiring of some sort, at least its fixed!
