Search In
  • More options...
Find results that contain...
Find results in...
Internet Speed Difference: Wired vs WiFi on same ISP
Hi,
I am currently on a bundled phone and DSL plan and my initial internet speed was 2 MBPS max download speed (averaging 258 kbps on torrents and steam). My ISP made an upgrade and my max download speed became 5 MBPS.
However, whenever I run a speed test, it still shows 2 MBPS as the max download speed. The test was done using my Desktop PC connected to the modem via cable. But when I run the speed test using my mobile phone, which is connected to the modem via WiFi, the speed is 5 MBPS.I then bought a USB WiFi adapter and connected my Desktop PC via WiFi and I got max download speed of 5 MBPS (averaging 680+ kbps on torrents and steam).
I tried getting help from my ISP's tech support several times. They run remote diagnostic tests and claimed to have made changes to the settings on my account but alas, they could not help me and could not even answer why the connection speed is faster via WiFi over cable.
My suspicion is I need to replace the cable or the modem but my ISP's tech support said that no replacement was needed. Any thoughts on this?
Even a 100Mbit network cable should give you up to 12.5MB/s. I would try a different wired device with a different cable. See if it performs different.
Guides & Tutorials:
Testing for RAM Errors w/ MemTest86
How To: Remotely Access a Computer, Server, or NAS
How To: Access Remote Systems at Home/Work Securely from Anywhere with Pritunl
How to Format Storage Devices in Windows 10
A How-To: Drive Sharing in Windows 10
VFIO GPU Pass-though w/ Looking Glass KVM on Ubuntu 19.04
A How-To Guide: Building a Rudimentary Disk Enclosure
Three Methods to Resetting a Windows Login Password
Guide/Tutorial in Progress:
iPXE Network Booting to an iSCSI Target
In the Queue:
Don't see what you need? Check the Full List or *PM me, if I haven't made it I'll add it to the list.
*NOTE: I'll only add it to the list if the request is something I know I can do.
I know it seems like a long shot, but have you disabled then re-enabled your ethernet port adapter? Sometimes it needs a bit of a kick to re-negotiate speeds with the modem, and sometimes it needs just a good reset.
I only got one pc. I don't have a laptop too to test that.
I already did that. Still the same results.
Well, next option I would try is turning auto-negotiate off on both the switch port and your PC, then setting both to 100 or 1G full duplex and trying that.
DSL still exists? Anyways what kind of modem do you have?
I like to play games and eat cookies.
I also build and sell gaming computers.
