Thermal paste and AIO choice.
Go to solution Solved by glenalz81,
If you're thinking 120mm AIO i would strongly suggest a decent air cooler. 120's get saturated fast and don't really perform any better and often worse.
I generally buy the 8g tubes of MX-4 which is plenty for multiple pastes and performs very well.
Hi, i was wondering if thermal grizzly kryonaut would be good for an rx 590 and a ryzen 5 3600 (non x). I was considering getting a corsair h60 120mm AIO, i dont need anything bigger. Are there any better 120mm aios and would that thermal paste be best for gaming and said cpu and gpu type?
https://linustechtips.com/topic/1114584-thermal-paste-and-aio-choice/
120mm AIOs aren't any better than $20 120mm air coolers unless your space is very limited.
Probably get a Neptwin or Scythe Fuma 2 if you want better cooling on the cheap.
MX-4 is fine on it's on, you don't need to repaste your GPU.
17 hours ago, Palden said:
At 120mm, unless you're getting a REALLY thicccc rad, you're best off with (my cooler of choice), a hyper212 evo, now going for $30
Alright, i just need adequate cooling with a low profile and not a big beefy heatsink you know, if you have any great air coolers that arent huge my budget is around 80-100
Would replacing the stock paste with said arctic mx-4 help temps or would the benefit be negligible? (Edit: for the gpu)
Edited by TreyYaBoy
It's not worth the 1-2 degrees you might gain, you'll only want to worry about repasting it in like 4-5 years or so.
4 hours ago, Palden said:
@TreyYaBoy
I would go look at Noctua's heatsink lineup then, they have some really great low-profile air coolers, they're just a little pricier than regular tower-style heatsinks.
Do they cool as adequate as a normal heatsink? Especially under load im gonna be gaming and streaming and ive heard noctuas name fly around before.
