External Touchscreen-Display for Android-Smartphones (phone wall calendar)
Hello everybody,
I am looking for a touchscreen monitor, which remains permanently connected to an Android device and is able to control it. It should primarily serve as a kind of wall calendar. The monitor should be as flat (<= 3cm) as possible, around 15.6'' large and with no internal battery. With portable monitors, I seemed to come closest to what I was looking for, but could not find one that would support the simultaneous mirroring of the phones screen and charging.
Does anyboday have an idea? Maybe with an intermediate hub or something similar?
Android devices generally do not support external displays through microUSB/USB-C connector. There have been some devices, that had MHL or microHDMI output though. Plus the output might be bandwidth-limited when the port is USB 2.0. Even if you can connect a display, it's not going to support touch functionality. Android doesn't have capability/support for that.
Why do you specifically want to use Android device? Why not Raspberry Pi? Latest version (4 Model B) can even output 4K signal via microHDMI ports. This gives you much wider option of panels to use. Plus you get much better hardware support.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
There seem to be a couple of monitors that support touch functionality on Android. Linus reviewed the Gemini Portable, which however includes a battery and is currently sold out. Or the Desklab Monitor, which ended their campaign shortly after the start due to payment issues. (and I would not want to purchase a display which I would be unable to return, if it turned out that it does not work as intended)
Flexibility and I would prefer not to purchase yet another computer. Plus I would have to wait until there is a Lineage OS release for Raspberry Pi 4.
