How to use wireless headphones on pc ?
Go to solution Solved by UrbanFreestyle,
A quick look at the motherboard does not show onboard bluetooth so you would need a USB or PCIE etc module.
Enable bluetooth (via adapter)
Turn on headphones into sync mode (normally holding the on button)
Connect in Windows bluetooth manager
Rock out.
Rock out.
Rock out.
Hmmm. I did not know the board needed that. Interesting, another find to look out.... Anyway thanks. And it if ou're still here can you tell me how to add a password to bluetooth as well ?
