Hey,
I've never built a PC before and I recently decided that a PC would have considerably better performance than my Acer Spin 5 for video editing. I have a budget of $1000 and I am struggling to choose parts for my build.
This is the time to point out that I don't have a lot of tech knowledge but I do know the basics about the specs of a CPU and GPU (I can easily understand the language spoken in a pc building video made by Linus).
I was thinking of going for an Intel CPU - specifically the i7-8700K however I recently saw that the Ryzen 3700x had better performance in some areas as well as for obs streaming (although I don't stream, I am thinking of recording gameplay at some point). Regarding GPU, I would like a RTX 2060/70 however those cards a really expensive and especially with an Intel CPU, I think my build will go over my budget.
Display - wise, I have a Samsung QLED 144mz 1ms 27" 1080p curved ultrawide monitor if that means anything. I've heard a monitor can bottleneck a PC... I am planning on getting a new monitor at some point - filming at over 1080p will be a massive upgrade.
Can anyone help?
Thanks so much,
Noam
1 minute ago, emosun said:
do you cpu or gpu render? becuase you dont need a gpu in a video editing machine if you cpu render
This is when my noob-ness comes along - I have no idea. Is there a difference in performance?
Hello,
The 3600 is has good has a 8700k for half the price. No RTX but still a good card. The 3700x would be a little better for streaming/gaming/rendering but it's 350$ too.
well premiere has the option of cpu and gpu rendering. you should be reading through this first
https://www.pugetsystems.com/recommended/Recommended-Systems-for-Adobe-Premiere-Pro-CC-143/Hardware-Recommendations
I've read the article before but just now I've read about the differences between the two. I think I prefer GPU rendering as it is a lot faster.
Hey,
I'm planning on building a PC for the first time and recently discovered that my monitor can bottleneck my rig. I currently have a 27" 1080p 144mHz 1ms response rate Samsung QLED monitor with FreeSync and I'm planning on building a PC for mainly video editing and some gaming. I film and edit in 1080p (and obviously game in 1080p) but say I shot a film in 1440p, can I edit and export it in 1440p, although I won't be able to see the quality?
Also, will having a really powerful graphics card (say RTX 2060 or higher) differ in performance substantially from a GTX 1080/1660 Ti on my monitor as it is only 1080p? Or will my monitor bottleneck my PC?
Any help is greatly appreciated,
Thanks so much,
Noam
No reason not to use gpu acerlation in premiere. GPU encoding has worse quality for h264, but id use the extenion so you can use nevnc as its better than quicksync.
It doesn't really work that way. You can zoom in if you want, and it will still export at full quality.
But getting a 2160p monitor is nice for this as you can have full res video + tools on the side.
In most video editing porgrams having a very highend gpu won't help much so a 2060 or 1660ti is the best bet. With editing the monitor resolution won't affect performance.
How do I select GPU acceleration in Premiere. Is it automatic?
How substantial is the quality difference in h264?
So I will be able to export in higher quality even if my display is 1080p?
With my budget of $1000, is buying a 1660 ti a better deal than buying an rtx 2060?
Thanks for your help!
In project settings
Moderate, much bigger at low bitrates, won't notice it at high bitrates. Experment for your self.
Yep, monitor won't affect export quality or resolution at all.
Yea id focus more on cpu, a 1660 or 1650 should be plenty for most premiere stuff in that budget.
Would you recommend a Ryzen 7 3700x?
Is there anything that a 1660 will struggle in?
Yea a 3700x is a pretty good pick here.
Not much that gpu would strugge in unless you doing lots of very gpu effects heavy work. Normal editing is normally more cpu limited.
thanks!
