Normally just need a tee fitting and a male to male swivel. I buy Q fittings as they are cheaper at the store and I have a lot of plugs sitting around.
But if you get a pump res that's designed properly like singularity computers, it will have a drain port on the pump top which is designed for a res. Not just using a male to male fittings.
