This is a new Lenovo prebuilt with a RTX 2060. You can hear its the fans doing that on the recording as i change the fan speed on Afterburner. It wasn't like this when i bought it a month ago, it started about 7 days ago.
Is this something that i should go complain about or does it fall in the "normal" range?
thanks in advance for any help :)
GPUNOISE.mp3
https://linustechtips.com/topic/1113880-need-opinions-on-gpu-fan-noise/
Probably a bad bearing in a fan
