Helo guys.
Curretly, I have MSI GeForce GTX 1080 AERO 8G (blower style cooler) in my build, but I have a chance to get MSI GeForce RTX 2060 VENTUS 6G OC (open 2 fan style cooler) from my work for approx. the same cost I would be able to sell my GTX1080.
I play mainly at 1440p/60Hz monitor and some lighter games at 4K/60Hz TV, so performance shoud be roughly the same.
I am very happy with ma GTX1080 performance,but 2060 will produce less heat (tested) under load.
I will play RDR2, new Star Wars Jedi Fallen order and Cyberpunk 2077 whe they come out.
Both cards match my build, so I don't have to care about looks.
What do you think, is it worth upgrading?
Thanks for opinions and suggestions.
https://linustechtips.com/topic/1113733-get-rtx2060-or-keep-gtx1080/
You'd be downgrading?
Wat
Just now, Fragment323 said:
I have looked at benchmarks in games online, performance looks almost the same for my needs. That is why I am asking for opinions.
So why sidegrade?  If they're the same, what is your reasoning?
Onyx: AMD Ryzen 7 7800x3d / ASRock Taichi 7900xtx OC / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 1000 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
OnePlus Ecosystem:
Other Tech:
2 minutes ago, Fragment323 said:
Heat, mainly. Newer card, also. Aero is very hot event with good airflow. I can get about 15-20 celsius lower.
Well then it looks like you answered your own question :)
OnePlus Ecosystem:
Other Tech:
1 minute ago, c00face said:
I see what you're trying to get at. But you haven't stated rather the rtx 2060 is used or not. If it's new, and you're able to get it by selling your gtx 1080, the answer is of course! If both is used, you have to think about longevity of the card. Do you trust your 1080 more than the overclocked rtx 2060? Both cards have similar functions, fairly close in performance, and rtx being newer in tech.
Personally, if the rtx 2060 is used, I wouldn't do it. 1080 beats it with 8gb of vram, slightly better performance, and you know what you've done with the 1080 card. As with the rtx 2060, you have no idea whats been done to it, and just to swap because it isn't a reference card with newer tech, isn't really worth.
1080 is hotter, almost no OC potential, used for about a year and half.
2060 has rather big OC potential (better cooling), it was unpacked today, will be used for video analytics testing for month or two, than I can buy it.
Its not necessarily that it produces less heat, its that two fans cool it better.
Even if it does, its venting some of that heat into your case now compared to your old card which exhausts entirely out of it. So actually the rest of your system might run hotter.
Venting out exces heat from case is not a problem in my case.
37 minutes ago, c00face said:
no brainer. ill swap it for the rtx 2060. if its only been used for at least two months just for video analytics. swap it.
warranty still active.
only been used for 2 months for video analytics.
has better fans.
newer tech.
slightly lower performance, but debatable.
i wouldnt OC it if youre wanting better cooling. and besides, it already comes by default OC. so you'll see better performance on the 2060 than your reference 1080.
but the real question is did your company purchase the rtx 2060 used or brand new?
Brand new.
