I’m trying to figure out the best way to format this 2 TB USB drive I just bought. It’s 2.0 USB and it is 2 TB. I’ve done a quick format but it still comes up with errors when trying to read data from it. But when I do alone format it seems not to move. Is it just take a really long time to format a 2 TB USB 2.0?
With Great Power Comes Great Responsibility
https://linustechtips.com/topic/1113563-best-way-to-format-a-2tb-usb-20-drive/
Yes, USB 2.0 is fricking SLOW. It's about 30MB/s, so it takes about 19-20 hours for a full format of 2TB.
Where did you buy it from? For one, a 2TB USB-drive with USB2.0 raises an immediate alarm for me. It should be USB3.0. Secondly, errors? Another red flag. Lemme guess: you bought it on eBay or Amazon?
This - a 2tb USB2.0 is likely a 16gb flashed to show 2tb USB 2.0.  This is an old scam.  Even Newegg Marketplace has these fake sticks listed.  Or did you get the DataTraveler Ultimate GT from Kingston...except that would be USB 3.1 (if you catch my drift).  Also these costs hundreds and hundreds of dollars.  If you paid something that seemed to good to be true - you should request a refund immediately.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
well i managed to get a refund and told me to keep it. came from china so i was leary once i saw china post as source. but figured id give it a try at least. but yeah it was on amazon. figure usb 2.0 2tb was doubtful but wasn't much either with cuon code i had.
