Will a Pci-e 3 gpu work in a 2.0 slot?
By
BetaA
in Graphics Cards
in Graphics Cards
Solved by emosun,
the correct answer is "it's supposed to"
I say this becuase back in the day pci-e 1.0 , 1.0a , and 1.1 had compatibility issues on old boards. but provided your machine has no specific bios updates related to gpu compatibility then a 3.0 card should work in a 2.0 slot
3
3
d-hubs ·
Posted in Linux, macOS and Everything Not-Windows0 -
BowlOfSomething ·
Posted in New Builds and Planning5 -
BocchiTheRock ·
Posted in Laptops and Pre-Built Systems1 -
2
18
whytthundr ·
Posted in New Builds and Planning8 -
4
play_circle_filled
Latest From Linus Tech Tips:
Companies are Suing Honest Reviewers and it’s Going to Get UGLY.
