Coil Whine in games but not on Aida64 ?? [HELP]
Hi!
Im getting a weird noise (probably coil whine) when im playing games.
It's weird because if i use Aida64 to stress my PC there's no noise. I tried stressing my GPU only, nothing, then i tried stressing everything (CPU, GPU, Disk etc) and still no noise!
It doesn't make any sense. Why do i get this noise only when im playing but if i use a stress software nothing happens ? I was monitoring my GPU while playing Battlefield 1 and on Aida64, i have high frequencies and usage on both, so i don't see what's going on...
Could someone help me ? I also have this video so you guys can hear it, thanks !
Specs:
Ryzen 7 3700X
16GB (8x2) Corsair Vengeance LPX 3200Mhz DDR4
Sapphire Pulse 5700 XT
Asus X570 TUF Gaming Plus
Seasonic Focus Plus Gold 750W
SSD M.2 Intel 660p 512GB
https://linustechtips.com/topic/1113439-coil-whine-in-games-but-not-on-aida64-help/
It can depend on how much the GPU is stressed and also which parts. My GPU has no coil whine, unless I run older benchmarks that run at 1000+ fps. Then its really audible.
computers are funny like that.
Firstly , coil whine isn't a problem , so don't worry about it.
Second , One reason (least with analog signals) is that a gpu being mathmatically stressed vs a gpu actually sending frames out to a monitor will have different interferences that could occur between the monitor and machine. So a simple stress test that isn't the exact same game or program can produce different conditions.
Your only real issue (which we can't solve) is more along the lines of how quiet your house is vs how loud the coils in the machine are.
Coil Whine is often FPS related. More FPS=More Coil Whine.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
Thanks for your help. But how can i be sure it's coil whine ? Could be anything else. The noise is a bit annoying but i can live with that, Im just worried it can damage my PC
Just now, f0dafone said:
yeah makes sense, if i run 3DMark i hear the noise. But i don't get high fps on Battlefield1...
Nothing you can do about it. But it isnt harming your Card if thats your concern.
Not much else in the pc makes a perfect noise like that on command.
one way to toggle the noise on and off just to make sure would be to play a game then set the resolution incredibly low during the game to see if the noise changes under identical conditions with the only variant being the resolution thus the load on the gpu.
But why some GPUs have it and others don't ?
becuase some peoples computers are closer to their heads and some people have overly quiet houses and noise standards.
again its more a human problem and less of a computer problem.
Totally unrelated but people sometimes complain about how loud a fuel pump can be in a car , which i'm willing to bet you've probably never ever heard becuase you're just a different person than those people. lol
i see, thanks. But i just used FurMark to test the GPU and still no noise!! High fps (139 avg) and still no noise! I don't get it :/
http://www.ozone3d.net/gpudb/score.php?which=807640
are you playing furmark as a video game?
or are you playing a totally different game which is programmed entirely different from furmark?
2 different conditions yeilds 2 different results , interesting
Especially considering that a car isn't exactly a quiet environment to begin with :D
I would say coil whine also depends on natural manufacturing variances and the types of coils used in different products.
yeah i think, it's on fullscreen and i can see the fps so.. Idk man. GPU it's on full load, high frequencies just like when im playing.
Damn mine's not that loud hahaha
I feel like if i type "different conditions" for a third time it still won't sink in so I'll let someone else try their hand at helping you out.
The interesting part is around 1:50, you can hear the whine changes pitch depending on what's on the screen.
yes. a slightly different coil , slightly different manufacturing process , one part sat on a shelf longer than another , one parts solder is slightly different at a chemical level... ect....
Oh sorry, didn't noticed that part. Yeah it's different conditions, obviously. Im just trying to simulate it with these softwares, but i guess i will never have the same result (?)
if you aren't doing the same thing , then no. lol
play the game you want to play , i'm willing to bet you didnt buy the computer to run furmark
It's not just how much load the GPU has, but also which parts of it are under load. So yes, it really depends on the software and how it's using the GPU.
yeah i was just trying to see which component was making the noise :/
dont need to change software for that
run the game , open the door and listen to the componenets with your ear and located it , if it's around the psu or gpu , then it'll just be coil whine
i already did! I even placed my hand on the GPU and i honestly didn't heard or felt any vibration. It doesn't sound like it's coming from the GPU, honestly.
