Our Smallest Build EVER? - Velkase Velka 3
We build what might be our SMALLEST custom gaming PC ever, in the new Velkase VK3 / Velka 3.
Buy a Velkase: On their site: https://www.velkase.com/products/velka-3
Buy an AMD 3700X CPU:
On Amazon: https://geni.us/KHY4Erm
On Newegg: https://lmg.gg/8KV1c
Buy an ASUS Strix X570-i Motherboard:
On Amazon: https://geni.us/Y803S1K
On Newegg: https://lmg.gg/8KV15
Buy a Gigabyte RTX 2060 Mini:
On Amazon: https://geni.us/tQqcI
On Newegg: https://lmg.gg/8KV1z
Buy a Noctua L9a AM4 Cooler:
On Amazon: https://geni.us/ozdR
On Newegg: https://lmg.gg/8KV1P
Buy Corsair LPX Memory:
On Amazon: https://geni.us/MINRiBs
On Newegg: https://lmg.gg/8KV1m
Buy Corsair PCIe 4.0 NVMe SSDs:
On Amazon: https://geni.us/YeUKfFo
On Newegg: https://lmg.gg/8KV11
Buy SilverStone Flex ATX PSUs:
On Amazon: https://geni.us/n5VbBC
On Newegg: https://lmg.gg/8KV1W
widget.png?style=banner2
PC: 9800X3D, 96GB Trident Z5 6200 CL28, 5090 FE, 3.84TB CM7
NAS: Xeon W-2195, 256GB ECC, 180TB Storage, 1660 Ti, TrueNAS Scale
https://linustechtips.com/topic/1113146-our-smallest-build-ever-velkase-velka-3/
I love it, I want to make my own.
Although I'd make it cheaper for myself. Actually considering doing this.
I would use 1700
RTX 2060 still
16GB of 3000 RAM
B350 cheapest motherboard that would fit
One large M.2
Same case and PSU.
Main PC:
CPU: Intel Core i9 14900KS SP 109 (125P-79E) (6.1Ghz P-Cores 4.8Ghz E-cores) MC SP 88
CPU Voltage: LLC6 1.43V (real voltage 1.305V + - Temps 77-80 P-Cores, 66-68 E-cores)
Cooled by: Supercool Direct Die 14th gen full nickel
Motherboard: Z790 ASUS Maximus Apex Encore
RAM: GSkill TridentZ 2x24GB DDR5 8600Mhz CL38 (OC from 8000Mhz CL40)
GPU: RTX MSI 4090 Suprim X with EKWB waterblock
Case: My own case fabricated out of aluminium and wood
Storage: 4x 2TB Sarbent Rocket Plus Gen 4.0 NVMe, 1x External 2TB Seagate Barracuda (Backup)
WiFi: BE202 WiFi 7 Tri-Band card module
PSU: Corsair AX1600i with custom black and red cables with 2x Corsair 5V+ Load Balancer
Display: Samsung Oddysey G9 240Hz Ver. 5120x1440 with G-Sync and Freesync Premium Pro 1008 Firmware Ver, and 1x Electriq USB C 1080p 15'8 inch IPS portable display for temperature and stats, MSI 23'8 144Hz G-Sync
Fan Controllers:  6x AquaComputer Octo with 5 temperature sensors
Cooling: Three Custom Loops:
1st Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for GPU only cooling with 2x Koolance QDC3, red coolant
2nd Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for CPU only cooling with 2x Koolance QDC3, purple coolant
3rd Loop: 1x 240mm PE CoolStream radiator with 1x EKWB Revo D5 pump (RAM ONLY)
Total: 5x pumps and 13x radiators 50x 3000RPM Noctua Industrial fans
Keyboard: Razer BlackWidow V3 RGB - Green switches
Sound: Logitech Z680 5.1 THX Certified 505W Speakers
Mouse: Razer Basilisk Ultimate Wireless with charging dock
Piano: Yamaha P155
Phone: Oppo Find X5 Pro
Camera: Logitech Brio Pro 4K
VR: Oculus Rift S
External SSD: 256GB Overclocking OS
LaptopMSI Titan GT77HX V13RTX 4090 175W, i9 13980HX OC: P-Cores 5.8Ghz 3 cores and 5.2Ghz 5 cores and E-Cores 4.3Ghz, 192GB of RAM @5600Mhz @3600 (chipset limit),
12TB (3x4TB) of NVMe, 17'3 inch 4K 144Hz MiniLED screen, 4x 17'3 ASUS portable USB-C Monitors 240Hz, Creative Sound Blaster G6 Sound Card, Portable 16TB NVMe in TB4 enclosures (8x2TB), Razer Basilisk Ultimate Wireless with charging dock gaming mouse, Keychron K3 gaming keyboard with blue switches low profile, Logitech Brio 4K Webcam.
Hand held: ROG Ally with XG Mobile RTX 3080 with Keychron K3 low profile keyboard (Blue Switches) and Razer Hyperspeed V3 mouse and 4TB NVMe upgrade (WDBlack SN850X), with 100W 20000Mah power bank and portable monitor ROG XG17AHP 17'3 inch 240Hz with built in battery, and 518Wh Power station for Camping.
HTPC: 13900KS SP111 5.9Ghz P-Core 4.8Ghz E-Core 1.43V LLC7 (Real Voltage 1.4V) with Supercool Direct Die, RTX 3090 ASUS Strix White with Active Water Block, ASUS Strix Z790-F Motherboard, 2x16GB DDR5 8000Mhz running 7600Mhz CL38, 4x 2TB Samsung 990 Pro NVMes, 3x 360mm EKWB PE White rads 3x 480mm external XE EKWB rads with 2x D5 pumps (single loop) with 21 Uni fans, G5 Odyssey 144Hz 1440p monitor, Keychron K3 slim mechanical keyboard and Basilisk Ultimate mouse, Corsair Elite Wireless headset.
Now that's exactly my style, so much so that I preordered both the 3 and 5 when this was posted on floatplane, couldn't decide/figure out which would fit my needs.
Since my SFF rig update basically ended up turning more into a new rig than an update I'll have a full PC minus GPU at the end that I can sell, but my current LZ7 is so beaten up after 2 years of travelling that a new case is needed anyway... so I'll see which one works for my rig and build the other to sell with the 2nd.
...Except if my custom 3D printed variation of the 3 works out, then I'd cancel that.
21 minutes ago, pApA^LeGBa said:
So a Flex ATX PSU is meant for small builds, right? Why are there no modular ones then?
Probably because making actual consumer PC builds with them isn't really popular as of yet, so they're all made for industrial devices - most even don't have a PCIe power connector, think only 2 have some.
When looking for mine I came across a company who made a custom version of one with a modular board added at the end, but not only was it ridiculously expensive, at that scale the PCB and connectors actually start taking noticeably more space than just wires do so modular isn't really a luxury you want to make room for.
In my case I cut out the extra wires, and will probably shorten everything I do use.
F@H
GPD Win 2
I think its safe to say that at some point you have to call it quits on trying to shrink SFF builds to even smaller levels.
This is cool and all, but its too small. I mean its a nice trick to instead of building into a case you build the case around the parts, much like performance motorbikes are built around the engine, while choppers and more traditional upright bikes have a frame and the engine bolts in.
But being so incredibly compact introduces more and more restrictions. When fans have to be 10mm thick and the PSU has to be so restricted, it really starts to cause issues.
IMO whilst this is a nice little build, i think it just takes away to many options. I would rather build in a shoe/boot box sized case that can fit a regular SFX PSU, some normal fans and an AIO. it will be cooler, quieter, and be able to handle more components without being any more difficult to transport. Chances are what ever bag you use to transport that tiny build in from one place to another, would have no problem fitting something slightly bigger either.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
That's why I stated designing my own, find it stupid you have to go with those noisy fans when you can add a couple of mm and get Noctua 92x15's in.
But I never knew about Flex ATX before, and that does allow for significant space savings. An SFX PSU makes it hard to pack everything together well.
Going with the Velka 3's layout but slightly enlarged will nearly halve my current build's volume but without the compromises of the V3.
F@H
GPD Win 2
Just now, Mikh said:
In the outro, Linus talks about another vid where they upgraded his personal rig with a 3900X. Did I miss this video? Can't find it anywhere...
On Floatplane right now, will likely come soon.
F@H
GPD Win 2
I like the idea of having a small form factor PC to keep in the living room (couch gaming and VR), but surely you wouldn't need to go that much bigger to keep the size benefits without as much of a sacrifice when it comes to noise/heat. Anyone found a case that is the sweet spot?
It's all a question of compromise once you go much below 20 liters. I would say this is shockingly functional given the size it actually looks very usable if you can tolerate a bit of noise under load. If you want a compact no compromise build the node 304 has been around forever.  It could do with an update but it's pretty hard to beat a case that supports a full size atx psu, largish gpus, large dual tower air coolers and 4 or 5 2.5/3.5 drives in 19.5 liters.
I find myself wondering if a dc to dc psu might not make more sense then flex atx for this case. Picobox sells a 490 watt unit that is just a bare pcb with that you could make the case even smaller or support 2.5 inch drives and ditch the 40mm fan.
Node 304. It's basically designed to be a media center pc. I'm 90% sure it is what linus has in his living room. If you're willing to use an aio you can go smaller but realistically 20 liters is plenty small for most use cases. Something like this is really about showing off or because you want a super minimalist desk setup. This thing would look great if you built it with that asrock board with the thunderbolt port and used a pair of type c monitors plus a wireless keyboard and mouse.
That's a little monster of a PC, but if it comes to carrying it around you forget that you also need to drag a monitor and keyboard/mouse with it. It's diminutive size/weight becomes less of a feature.
On the other hand if you need that kind of performance and you are in a confined space (RV, small bedroom, tiny desk) and can only fit a smaller monitor, this thing would be totally awesome. MiniITX definitely is a form factor worth looking into for more case manufacturers and mobo makers.
Nice build.
4 hours ago, pApA^LeGBa said:
So a Flex ATX PSU is meant for small builds, right? Why are there no modular ones then? At least i found none, and i assume that LTT didn´t go with the one used for the lulz.
They actually went with one of the quietest ones available, as well. Most every other I've tried has been LOUD.
They're made for 1U and 2U server chassis, not SFF desktop builds. They also typically have only the bare minimum cable setup to them as well, so there's typically no need for them to be modular since you're likely going to use all of what's attached to it.
Wife's build: Amethyst - Ryzen 9 3900X, 32GB G.Skill Ripjaws V DDR4-3200, ASUS Prime X570-P, EVGA RTX 3080 FTW3 12GB, Corsair Obsidian 750D, Corsair RM1000 (yellow label)
My build: Mira - Ryzen 7 3700X, 32GB EVGA DDR4-3200, ASUS Prime X470-PRO, EVGA RTX 3070 XC3, beQuiet Dark Base 900, EVGA 1000 G6
Nice build.
Good point.  New video idea... all-in-one PC build.  The case contains everything you would need... maybe use a projector instead of a monitor, some sort of folding keyboard, etc, etc.  Could be interesting.
These videos are always frustrating to me, because everyone (I don't just mean LTT) wants to put super high end stuff in a tiny form factor. I'm much more interested in what a practical build would look like. Having it with an R5 3600 and a 1650 that doesn't require external power would be really interesting. A small, relatively affordable, and quiet system would have more use cases IMO.
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
I'd love to know what the db meter says for the "loud" portion of this, since it didn't sound very loud there (especially compared to something like the old Mac wind tunnel towers), and at which frequencies the loudness comes from (most likely the harmonics of the PSU fan?).
I somewhat agree with the above, I'd more likely put an R5 3600 in it if I were making it as a generic portable rig…but then I'd also be trying to find a better short GPU to put in it to fully support the gaming chops at 1440p.  If, on the other hand, it is more of a portable work station that should also be able to play games decently, then putting the higher core count CPU in with a 2060 makes sense like Linus did.  That'd be a pretty bangin' mini-editing station for on the go to multi-day events like trade shows when paired up with a good external RAID (bonus points for an M.2 SSD RAID for also being small and light).
That would be interesting, but I was thinking of a lower powered rig. The 1650 isn't a card I would normally recommend to anyone (especially with the RX 570 being cheaper and better), but lower power draw might mean the PSU fan might not be as noisy.
I was trying to find the video Linus alluded to as well, I don't even see it on Floatplane
Edit: The video in question is back up on Floatplane, Can't wait for it to hit YouTube so a friend of mine can see it
I wish they had a modular PSU with that form factor, or something you can run as an external PSU brick with thinner cables That would come in clutch. Something you can have better cable management with and braided cables for smaller sizes.
I honestly am going to build this. I have no reason not to and I've been looking for a holiday project.
Cheers
