Currently i have lg 24" ips monitor 75hz, but because of limited budget, i can buy either a higher resolution 29" ips 75hz monitor or 144hz 24"  inch vn panel monitor. Because on YouTube youtubers screaming how good 144hz gaming is, I feel like giving it a shot, but also at the same time i need bigger screen with slightly bigger resolution for multitasking and for movies, etc etc. What do you suggest?
https://linustechtips.com/topic/1113030-monitor/
75 Hz is already a noticeable step up from 60 Hz, and as it gets higher the difference starts to get smaller, so I think I would personally lean towards the more size. One important factor to consider though, is whether the pixel density of the new monitor is not too high. If it is, everything will be tiny and you would have to result to scaling if your eyes aren't comfortable with that.
PC SPECS: CPU: Intel Core i7 3770k @4.4GHz - Mobo: Asrock Extreme 4 (Z77) - GPU: MSI GeForce GTX 680 Twin Frozr 2GB - RAM: Crucial Ballistix 2x4GB (8GB) 1600MHz CL8 + 1x8GB - Storage: SSD: Sandisk Extreme II 120GB. HDD: Seagate Barracuda 1TB - PSU: be quiet! Pure Power L8 630W semi modular  - Case: Corsair Obsidian 450D  - OS: Windows 7
https://linustechtips.com/topic/1113030-monitor/#findComment-12961741
The 29" ips ultrawide monitor has resolution of something 25*** × 1080p i think it for got those extra pixels covered and if it didn't worked out, i'll simple return the monitor back to Amazon :P
https://linustechtips.com/topic/1113030-monitor/#findComment-12961754
I have 144hz. But i would go for 29" 75Hz  in your case. Thats more than enough for Gaming.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/1113030-monitor/#findComment-12961781
