BEST 2080 Ti for custom water cooling.
Hi folks, I am putting together my build for the new year and I can’t decide on which 2080 Ti to choose. The build will consist of a 9900K and an Asus Maximus XI Formula, and everything will be custom water cooled. So I would like to ask about which one should I choose as money isn’t a problem. I am planning on overclocking as much as possible as an enthusiast not something extreme. Thank you all in advance!
https://linustechtips.com/topic/1112845-best-2080-ti-for-custom-water-cooling/
The Founders Edition.
Personal Desktop":
Luna, the temporary Desktop:
Since you are going to take the card apart which will void the warranty.... then the manufacturer kinda doesn't matter as you will not be getting support anyway so just pick the highest clocked card you can find.
I agree
In some countries it doesn't void the warranty,for example the US,one of the manufacturers that enforce this is Gigabyte..
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE GTX 1660 GAMING OC @ Core 2085MHz Memory 5000MHz
Cinebench R23: 15669cb | Unigine Superposition 1080p Extreme: 3566
Yeah but money is no object , meaning he can just buy 10 of them and never consider warranty or support
Founders PCB has the most choices of waterblocks. Some custom cards are just custom coolers on founders PCB but finding out what card has what PCB layout is too much effort imo
Desktop benching:
7 hours ago, Avok said:
So it seems that getting the Founder’s is the way to go, however I should just get the highest clocked card out of the box, right?
Factory OC is meaningless, the FE not only is the easiest and most practical to get water locks for it also has a more than good enough PCB and a highly binned graphical processing u it.
Yes, nVidia keeps all the highest bins for themselves as the "manufactures" (TSMC who makes it but using nVidia's developed architecture).
Personal Desktop":
It does not void the warranty if you chose evga.
