After a lot of research so I can be somewhat adequate with PCs, I've put together a list of parts for my next build. https://pcpartpicker.com/list/GqPycq I have a $3000 budget (including peripherals) and I just wanted some others' opinion on it to make sure there are no big problems I missed. I plan on gaming and doing video editing on it and I plan to order parts around Black Friday/Cyber Monday for (hopefully) some better deals. Thanks for any help!
https://linustechtips.com/topic/1112647-need-final-opinion-on-3700x-build/
The PC itself doesn't need to go past like $1200-1300 max
And it's going to be easier to run 2 sticks of RAM at higher frequencies, 16Gbs of would be easier to run at higher speeds as well, I don't go past 16GBs while doing 4k 60fps video editing.
Really don't need a 2080 super for 1080p 240hz, you're mostly CPU limited anyways, some games might only go to 200fps or so.
PCPartPicker Part List
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core Processor  ($558.89 @ Amazon)
CPU Cooler: Cooler Master MasterLiquid ML360R RGB 66.7 CFM Liquid CPU Cooler  ($139.89 @ OutletPC)
Motherboard: Asus TUF GAMING X570-PLUS (WI-FI) ATX AM4 Motherboard  ($194.99 @ SuperBiiz)
Memory: Team T-Force Delta RGB 32 GB (2 x 16 GB) DDR4-3000 Memory  ($129.99 @ Newegg)
Storage: Silicon Power P34A80 2 TB M.2-2280 NVME Solid State Drive  ($244.99 @ Newegg)
Video Card: Asus GeForce RTX 2080 8 GB Dual Advanced Video Card  ($599.99 @ Newegg)
Case: Fractal Design Define S2 ATX Mid Tower Case  ($148.98 @ Newegg)
Power Supply: Corsair RMx (2018) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($139.98 @ Newegg)
Monitor: VIOTEK GN34CW 34.0" 3440x1440 100 Hz Monitor  ($399.99 @ Amazon)
Mouse: SteelSeries RIVAL 650 WIRELESS Wireless Optical Mouse  ($88.88 @ Amazon)
Headphones: Kingston HyperX Cloud II 7.1 Channel  Headset  ($85.38 @ Amazon)
Custom: Funko - POP! Games: Fortnite - Skull Trooper - Multi  ($8.07 @ Amazon)
Custom: Razer Hunstman TE ($129.99)
Total: $2870.01
Generated by PCPartPicker 2019-10-11 01:58 EDT-0400
I don't recommend a 240Hz monitor, it's a waste of money unless you're quite legitimately in the top 0.01% of players for whatever esport you're targeting. I played Overwatch in grandmaster and I absolutely don't believe for even a second that my monitor stopped me from hitting top 500, anybody who believes otherwise is an absolute fool that's kidding themselves.
I also don't recommend it because while the 3700X is great, it's not what you should be pairing that monitor with.
if you have to insist you think for yourself, i'm not going to believe you.
