Seasonic Focus Plus 550W Platinum still not safe?
Hi,
Yesterday I ordered the Seasonic Focus Plus 550W Platinum, but today I found out about https://linustechtips.com/main/topic/1093286-why-you-shouldnt-buy-a-seasonic-focus-plus-goldplatinum/, which tells me that the focus plus platinum is a bad psu. But I'm confused, as in the tier list it is still noted as tier A: https://linustechtips.com/main/topic/1045610-new-psu-tier-list/ .
So is my PSU bad or not? I could still return it. Also does it only hold for high watt usage gpu's? For reference, I'm also buying the 2060 Super MSI gaming x. Not planning to overclock or anything. Am I safe or should I return it?
im just kind of wondering why you spent the extra money for platinum on a relatively low wattage PSU... and i think just to be sure, so you don't run into trouble down the line, exchange it for a more reliable unit. something from Corsair's CM or RM line should do reasonably well here
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
Biggest reasoning was that I saw somewhere that the platinum is quite quiet compared to other models. And I value low noise.
But does the danger of seasonic focus plus still hold against low wattage psu's? Did the post about danger mean any wattage?
1 minute ago, pmihc said:
How do I test that it works fine? I thought u cannot measure ripple without any special hardware?
There's no specific testing you as an user can make, the issues exists and there's little difference between a 80+ gold and 80+ platinum on a mainstream usage computer.
While you're likely not to have any issues with the unit the bottom line is simply that there are better alternatives at this price point with more robust build quality, safer safety features and alike.
You already pulled the trigger and bought it so I wouldn't stress a whole lot unless you are sure you want a quieter higher quality unit, there are a few that fits the criteria like the RMx (2018) and the Straight Power 11
Personal Desktop":
Luna, the temporary Desktop:
If you are already powering your system with one and aren't having shutdowns, I wouldn't worry.
The issue discussed in the other thread is only a potential issue when the PSU is used in a completely unrealistic/stupid manner. It should not be a concern for you with your system.
Since you've already purchased it then I would recommend keeping it. Not worth the effort in swapping it over something that isn't going to be an issue, and that issue which won't affect users in real world use cases aside they're actually pretty decent units.
You can't, at least not without expensive test equipment like you mentioned. That's why it's important to buy something you can trust when it comes to power supplies.
Thank you for your response. And I did do research about it. I found multiple sources saying it was top tier, including this forum's tier. https://linustechtips.com/main/topic/1045610-new-psu-tier-list/ and https://www.gamingscan.com/psu-hierarchy/
It's just that I stumbled upon the other thread by chance today saying it suddenly wasn't.
32 minutes ago, pmihc said:
That's just someone that literally copy pasted the old PSU tier list, without giving credit or sources. In the future, I recommend avoiding that site and not trusting anything they claim.
What about the former link?
5 minutes ago, Tadej Danev said:
You ordered new GX series or which one is it?
https://azerty.nl/product/seasonic/3132772/focus-plus-550w-platinum-voeding--intern--atx12v--eps12v
This is the one that I ordered. I think it is still the old one? (Excuses for the website being Dutch, but specs should still be readable)
