No DVI port on my GeForce
Gusto
My GeForce armor Rtx 2070 doesn’t come with a DVI port so I need to buy an adaptor because my Acer only comes with DVI cables. My question is do I need a DVI to HDMI, or an HDMI to DVI adaptor? I know it seems so dumb, but I’m a scatter brain and don’t want to accidentally buy the wrong one
Actually, you need Display Port to DVI.
M.S.C.E. (M.Sc. Computer Engineering), Senior IT advisor in a hospital, 30 years of gaming, 20 years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Philips 226VL - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/7 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Streaming/Server/Storage PC: AMD Ryzen 5 3600 - LC-Power LC-CC-120 - MSI B450 Tomahawk Max - 2x4GB ADATA 2666 DDR4 - 120GB Kingston V300 - Toshiba DT01ACA100 1TB - Toshiba DT01ACA200 2TB - 2x WD Green 2TB - Sapphire Pulse AMD Radeon R9 380X - 550W EVGA G3 SuperNova - Chieftec Giga DF-01B - Logitech G710+ - Roccat Kone Pure Military Desert strike - Logitech S-220
If your monitor only needs DVI Single Link (as in 1920x1200 60 Hz or lower), you can use a basic HDMI-DVI adapter and a hdmi cable :
Amazon.com: AmazonBasics HDMI to DVI-D Adapter - 2-Pack: Electronics
You can find these for 1-2$ on eBay. HDMI cables can be found anywhere.
If you need higher resolutions, you'll want DisplayPort to DVI ACTIVE converters. No guarantee you'll get more than 60Hz , depends on converter.
Do those adapters work for the dual link for high res monitors? I've read so many mixed reviews etc that I just don't know if they even work :/
·Ï¢årµ§·
i7 4790k · 32GB Kingston HyperX · MSI Gaming 5 · ... · 30" HP ZR30W + 27" Samsung 275T · 2x240GB Intel 530 in Raid 0 + 2x1TB Crucial MX500 · Lain-Li X2000F · Antec Signature SG-850 · BeQuiet! Dark Rock 3 Pro · Logitech Z5500 · Win10pro 64bit
If it's an ACTIVE converter which advertises DUAL LINK, then they'll do up to something like 2560x1600 or 3840x1440, I'm not sure about 4K on DVI.
It may be possible to get more, but by lowering the refresh rate to 50 Hz or 30 Hz.... and again, depends on the converter chip inside the active converter.
