Just replace with some good thermal paste, like Prolimatech PK-3. Don't use thermal pads.
CPURyzen 7 5800X with Arctic Liquid Freezer II 120mm AIO & push-pull Arctic P12 PWM fans RAM: G.Skill Ripjaws V 4x8GB 3600 16-16-16-30
PSU: Be Quiet! Pure Power 12 M 1000W GPUASRock RX 5700 XT Reference with Eiswolf GPX-Pro 240 AIO & 2x Arctic P12 PWM fans Case: Antec P5
MotherboardASRock X570M Pro4 Monitor: ASUS ROG Strix XG32VC Storage: HP EX950 1TB NVMe, Mushkin Pilot-E 1TB NVMe, 2x Constellation ES 2TB in RAID1
https://hwbot.org/submission/4497882_btgbullseye_gpupi_v3.3___32b_radeon_rx_5700_xt_13min_37sec_848ms
I mean for VRM and memories not the chip itself, I done some researches and I saw people uses thermal pads for those.
The thing is that am confused about the thickness as I read people says 1.0mm,1.2mm,1.5mm etc...
so I want to ask if anyone know what to use for my GPU, or at least give me a general rule on how to pick the right thickness for thermal pads.
Use thermal paste for that too... It's not going to be worse than pads for cooling, and if you aren't using some super liquidic stuff, there should be no issue at all.
