1. Budget & Location
northeast USA
would like to stay under $2500 if possible
2. Aim
i typically play older games but would like to venture into newer heavy gaming(prefer immersive rpgs , but also have an interest in anno 1800 just restricted by my dated rig. may also would like to dip into VR in the future when i can afford a headset(opinions on that would be great too)
also run programs in the background (ie discord, 2 to 3 web, vpn)
I'm torn on what monitor or monitors to get. i don't need super extravagant but a decent refresh rate and resolution. im leaning towards an ultra wide currently, 35in but also tend to used a second monitor on occasion.
i don't plan on doing any overclocking hence just the stock cooler with the ryzen cpu
4. Peripherals
i have access to windows education for free and as far as peripherals im using razer naga and anasi keyboard logitech g933 headset and plan on using them in the new rig. may also get the farming simulator wheel/side controller (go ahead and laugh)
5. Why are you upgrading?
short answer is its time. 5+ year old rig has trouble running most any game. some games are only playable on the lowest settings . have also been experiencing blue screens rather often that i have neither the time/ adequate knowledge to address.
PCPartPicker Part List
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  ($328.90 @ OutletPC)
Motherboard: Gigabyte X570 AORUS PRO WIFI ATX AM4 Motherboard  ($258.99 @ SuperBiiz)
Memory: Corsair Vengeance RGB Pro 32 GB (4 x 8 GB) DDR4-3200 Memory  ($409.99 @ Newegg)
Storage: Samsung 970 Evo Plus 1 TB M.2-2280 NVME Solid State Drive  ($214.99 @ Amazon)
Video Card: Gigabyte GeForce RTX 2070 SUPER 8 GB GAMING OC 3X Video Card  ($549.99 @ Newegg)
Case: Corsair iCUE 220T RGB Airflow ATX Mid Tower Case  ($109.99 @ Best Buy)
Power Supply: Corsair RM (2019) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($109.98 @ Newegg)
Case Fan: Corsair iCUE SP120 RGB Pro 52 CFM 120 mm Fan  ($24.99 @ Amazon)
Total: $2057.80
Generated by PCPartPicker 2019-10-08 23:01 EDT-0400
https://linustechtips.com/topic/1112020-2nd-build-need-input-on-my-ryzen-build/
970 evo and 32gb of ram is unnecessary, same thing with the 850w PSU.
Motherboard: Asus TUF GAMING X570-PLUS (WI-FI) ATX AM4 Motherboard  ($194.89 @ OutletPC)
Memory: OLOy WarHawk RGB 16 GB (2 x 8 GB) DDR4-3000 Memory  ($61.99 @ Newegg)
Storage: Team MP34 1 TB M.2-2280 NVME Solid State Drive  ($108.99 @ Newegg)
Video Card: Gigabyte GeForce RTX 2070 SUPER 8 GB WINDFORCE OC 3X Video Card  ($499.99 @ Newegg)
Case: Corsair SPEC-DELTA RGB ATX Mid Tower Case  ($79.99 @ Best Buy)
Power Supply: Gigabyte 750 W 80+ Gold Certified Semi-modular ATX Power Supply  ($71.98 @ Newegg) only here because it's cheap but still pretty decent, you only need a 500w PSU for a 2070 super.
Total: $1346.73
Generated by PCPartPicker 2019-10-08 23:27 EDT-0400
