New PC. Graphics card turns on but no monitor output. Is my GPU installed correctly? I have tested 2 GPUs.
Hardware (all brand new):
MOBO: ASUS X570-P with Ryzen 3600
GPU: RTX 2060 SUPER Gigabyte 8GB OC.
Problem 1: I didn't hear the satisfying "click" when I inserted the GPU into the top slot. Nonetheless, the locking mechanism worked and the GPU is in place, but no "click" sound.
Problem 2: When I turned on PC, the GIGABYTE logo turned on (indicating power is being received), but my monitor does not receive any video signal. Have tested on the TV too, same thing.
What I have done:
- I have tried two different PCIE slots with two different GPUs (other is GTX 680 - is this too old for X570?).
- Reset CMOS by removing battery for 60 secs.
- Multiple monitors/HDMI cables.
Is my GPU even installed correctly? Is there supposed to be a gap here? PLEASE HELP!!!
https://imgur.com/a/kMeGdnk
and yes HDMI is connected to GPU.
1. Make sure the GPU has auxiliary power connected.  (In your pictures it looks like it does.)
2. Does it boot up with HDMI connected to the mobo?  If so, then there may be a bios setting to disable GPU.
Don't be afraid to give it a firm push to ensure it's properly in place. Looks ok though.
The GTX 680 should work fine, if not then maybe a motherboard issue?
CPU: AMD Ryzen 5 2600X  |  Cooler: Cryorig H7  |  Motherboard: MSI B450 Mortar  |  Case: Fractal Design Meshify C Mini  |  RAM: 32GB DDR4 3000MHz  |  GPU: EVGA 1070ti Gaming (Kraken G12 Watercooled) |  PSU: Corsair TXM650  |  Storage: Samsung 860 EVO 500GB + WD Blue M.2 500GB  |  Network Card: Asus PCE-AC56  |  Monitor: Acer Nitro VG270U  |  Audio: Sennheiser HD6XX + Schiit Fulla 2
Laptop:
Lenovo s540:  CPU: AMD Ryzen 5 3500U  |  RAM: 8GB DDR4 2666MHz  |  GPU: AMD Radeon Vega 8  |  Storage: 256GB NVME SSD
11 hours ago, wolvaus said:
WTF!
I removed 1 RAM stick and it worked!??!?!?! I have video!!!!
Why does this even work? Is my RAM defective?
Yup. 1 stick is dead or glitchy, or the RAM slot is dead or glitchy. It happens.
CPURyzen 7 5800X with Arctic Liquid Freezer II 120mm AIO & push-pull Arctic P12 PWM fans RAM: G.Skill Ripjaws V 4x8GB 3600 16-16-16-30
PSU: Be Quiet! Pure Power 12 M 1000W GPUASRock RX 5700 XT Reference with Eiswolf GPX-Pro 240 AIO & 2x Arctic P12 PWM fans Case: Antec P5
MotherboardASRock X570M Pro4 Monitor: ASUS ROG Strix XG32VC Storage: HP EX950 1TB NVMe, Mushkin Pilot-E 1TB NVMe, 2x Constellation ES 2TB in RAID1
https://hwbot.org/submission/4497882_btgbullseye_gpupi_v3.3___32b_radeon_rx_5700_xt_13min_37sec_848ms
