Which one to keep?
12 members have voted
  1. 1. Which ones to keep?
    • Noctua
      7
    • Corsair
      5
I thought someone might have use from this info so here it goes!
I wanted to get better temps by upgrading the fans to Noctua Industrial series.
Setup is 2x 2080 Ti and 9900K.
Cooling: 3x 480mm rads and 1x 240mm rad. 60mm thick each.
Variables: 14x NOCTUA iPPC 3000RPM 120mm vs 14x ML120 Pro RED LED 120mm.
Fans were run at their max initially.
Used game I play the most at 3440x1440 at 120FPS locked.
Pumps speed always maxed out.
Noctua:
1st round of test:
32C 1st GPU and 34C 2nd GPU. 3000RPM. Open case.
2nd round of tests:
33C 1st GPU and 35C 2nd GPU. 2000RPM. Open case.
3rd round of tests:
35C 1st GPU and 37C-38C 2nd GPU. 1000RPM. Open case.
CPU in all these tests was always either 47 or 48C.
Now I closed the case (as in panels).
1st and only round at 3000RPM:
33C and 36C respectively for GPUs, case closed.
Corsair:
1st round of test:
34C 1st GPU and 36C 2nd GPU. 2400RPM. Open case.
2nd round of tests:
35C 1st GPU and 37C 2nd GPU. 2000RPM. Open case.
3rd round of tests:
37C-38C 1st GPU and 40C 2nd GPU. 1000RPM. Open case.
CPU was around 49-51C throughout these tests.
What I was hoping Noctua fans would do is provide a fairly better temps than ML120 Pros. They do reduce the temperatures further by couple of degrees for sure, but the cables are much shorter and harder to manage.
Noctuas move 110 CFM each whereas Corsair ones move 75CFM.
Static pressure of Corsair is 4.2 and Noctua 7.6.
Noctua is slightly louder at 2000 Vs Corsair and a little bit louder than Noctua at 2900RPM.
Which one should I pick to stay?
(I love low as hell temps but I don't think this is significant)
Cables for Noctuas are nice but not long enough and the all produce the same noise no matter the fan whereas Corsair ones have tendency to create motor noises or ticking until they settle (or they don't settle and they just tick)
Noctua ones are slightly louder about 20% I'd say.
They can all surprisingly go to the same RPM, even 500.
Also, the Corsair ones fit the build better with red LEDs.
Also pricing:
17.99 for Corsair with superior Amazon returns etc or 22.99 from Overclockers.
I can return either ones. Can't keep them all.
It was all controlled through 3x commander pro.
Main PC:
CPU: Intel Core i9 14900KS SP 109 (125P-79E) (6.1Ghz P-Cores 4.8Ghz E-cores) MC SP 88
CPU Voltage: LLC6 1.43V (real voltage 1.305V + - Temps 77-80 P-Cores, 66-68 E-cores)
Cooled by: Supercool Direct Die 14th gen full nickel
Motherboard: Z790 ASUS Maximus Apex Encore
RAM: GSkill TridentZ 2x24GB DDR5 8600Mhz CL38 (OC from 8000Mhz CL40)
GPU: RTX MSI 4090 Suprim X with EKWB waterblock
Case: My own case fabricated out of aluminium and wood
Storage: 4x 2TB Sarbent Rocket Plus Gen 4.0 NVMe, 1x External 2TB Seagate Barracuda (Backup)
WiFi: BE202 WiFi 7 Tri-Band card module
PSU: Corsair AX1600i with custom black and red cables with 2x Corsair 5V+ Load Balancer
Display: Samsung Oddysey G9 240Hz Ver. 5120x1440 with G-Sync and Freesync Premium Pro 1008 Firmware Ver, and 1x Electriq USB C 1080p 15'8 inch IPS portable display for temperature and stats, MSI 23'8 144Hz G-Sync
Fan Controllers:  6x AquaComputer Octo with 5 temperature sensors
Cooling: Three Custom Loops:
1st Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for GPU only cooling with 2x Koolance QDC3, red coolant
2nd Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for CPU only cooling with 2x Koolance QDC3, purple coolant
3rd Loop: 1x 240mm PE CoolStream radiator with 1x EKWB Revo D5 pump (RAM ONLY)
Total: 5x pumps and 13x radiators 50x 3000RPM Noctua Industrial fans
Keyboard: Razer BlackWidow V3 RGB - Green switches
Sound: Logitech Z680 5.1 THX Certified 505W Speakers
Mouse: Razer Basilisk Ultimate Wireless with charging dock
Piano: Yamaha P155
Phone: Oppo Find X5 Pro
Camera: Logitech Brio Pro 4K
VR: Oculus Rift S
External SSD: 256GB Overclocking OS
LaptopMSI Titan GT77HX V13RTX 4090 175W, i9 13980HX OC: P-Cores 5.8Ghz 3 cores and 5.2Ghz 5 cores and E-Cores 4.3Ghz, 192GB of RAM @5600Mhz @3600 (chipset limit),
12TB (3x4TB) of NVMe, 17'3 inch 4K 144Hz MiniLED screen, 4x 17'3 ASUS portable USB-C Monitors 240Hz, Creative Sound Blaster G6 Sound Card, Portable 16TB NVMe in TB4 enclosures (8x2TB), Razer Basilisk Ultimate Wireless with charging dock gaming mouse, Keychron K3 gaming keyboard with blue switches low profile, Logitech Brio 4K Webcam.
Hand held: ROG Ally with XG Mobile RTX 3080 with Keychron K3 low profile keyboard (Blue Switches) and Razer Hyperspeed V3 mouse and 4TB NVMe upgrade (WDBlack SN850X), with 100W 20000Mah power bank and portable monitor ROG XG17AHP 17'3 inch 240Hz with built in battery, and 518Wh Power station for Camping.
HTPC: 13900KS SP111 5.9Ghz P-Core 4.8Ghz E-Core 1.43V LLC7 (Real Voltage 1.4V) with Supercool Direct Die, RTX 3090 ASUS Strix White with Active Water Block, ASUS Strix Z790-F Motherboard, 2x16GB DDR5 8000Mhz running 7600Mhz CL38, 4x 2TB Samsung 990 Pro NVMes, 3x 360mm EKWB PE White rads 3x 480mm external XE EKWB rads with 2x D5 pumps (single loop) with 21 Uni fans, G5 Odyssey 144Hz 1440p monitor, Keychron K3 slim mechanical keyboard and Basilisk Ultimate mouse, Corsair Elite Wireless headset.
For me? The quietest. Temps don't matter as long as it's not throttling (or reducing boost).
F@H
GPD Win 2
Is noise a concern?
Desktop benching:
10 hours ago, Jurrunio said:
Is noise a concern?
It's not, I use headphones anyway and if not I can get them to any RPM with Commander Pros so they won't cause noise.
Main PC:
Piano: Yamaha P155
VR: Oculus Rift S
use the 3000rpm fans then
Desktop benching:
So to summarize:
If you return the Noctua
- You get 90 pounds (more) than returning the Corsair
- You have a lower maximum cooling capability
- You get red LEDs
If you return the Corsair
- You get 90 pounds less than returning the Noctuas
- You have a higher maximum cooling capability
- You don't have LEDs
Since you say you don't care for noise, it ultimately boils down to whether you want the extra 90 pounds, and how important the red LEDs are to you. Since you bought a crimping set earlier for your D5 pump, fabricating your own cable extensions/splitters is now easy and so cable management should be a non-issue.
if or(extra 90 pounds, red LED) = important then
    return noctua
elseif absolute performance = important then
    return corsair
fi
Could return them both, and get the more fancy Corsair ML120s with full RGB options, then have some wacky lighting to match the completely beast system you built. I know the red fits the build more, but what happens when you want to change up the color profile for fun? Plus you can download completed lighting profiles and slap em right on your system. Also, if the fans last, you can use the wider color choices in future builds, or future upgrades of the current one.
My First (Current) Build:
Ryzen 7 2700 (3.90 1.35v OC) | Asus Prime X470 Pro | G.Skill Ripjaws V 16gb 3200 | Inland Professional 512gb M.2 NVME | Samsung 860 Evo Sata M.2 1TB | Corsair H115i Platinum | Corsair ML 140 RGB Fans | Fractal Design Meshify C | EVGA RTX 2070 XC Ultra
Laptop:
HP Spectre X360 13t Gem Cut (i7 8565u, 240gb, 8gb mem)
My Ride:
2015 VW Golf TDI Sportwagen
Eventually an XJ manual...
I would use 2k noctua and have great temps and less noise and keep the good looks.
Prefer the lower minimum rpm speed as well compared to the 3k variant. I say that even as a headphone user primarily.
14 hours ago, For Science! said:
So to summarize:
- You get red LEDs
    return noctua
    return corsair
fi
I actually had 6 Noctuas already so I'll get the same amount whether I return Corsair or Noctua. I can return 14x Corsair ones or 10x Noctuas. I think I'll stick with Noctua. I can add LED strips and have LEDs. Love the sudo code there haha.
Coolant is red, so it wont look great. I had RGB HD120's and it was okay at best.
I can get these 3000 RPM ones spin at 500 to 3000 RPM. Commander Pro 3x allow me to just change the speed in software.
Main PC:
Piano: Yamaha P155
VR: Oculus Rift S
None of the hubs I use allow them to spin that low. They either stop or I’m stuck hearing them click.
My Commander Pros allow them to spin ultra slowly (which is ultra cool).
Main PC:
Piano: Yamaha P155
VR: Oculus Rift S
Thanks for responses, I kept Noctua, not very audible at 750RPM so I left them at this RPM.
Main PC:
Piano: Yamaha P155
VR: Oculus Rift S
