So I'm driving a Daewoo Nubira 1.6 2002 Petrol. Manual/stick gear
When releasing the throttle there is about 1-1.5 second delay before the engine actually reacts to it.
You can feel it if you run about 80km/h /50mph? - in third gear at about 4000 rpm, then let go, it'll react after 1-1.5 seoncds..
I've tested it also by releasing the throttle then instantly pressing the clutch. Sure enough RPM's start to drop after 1-1.5 seconds.
Before that the RPM's pretty much stay where they are.
So what gives? it makes it hard to time gear switches with RPM's if you wanna do it fast.
AMD Ryzen R9 5900X  | Arctic Liquid Freezer II 360  |  GIGABYTE X570S AERO G  |  2x32GB G'skill TridentZ 4000MHz  | MSI RX 6900 XT Gaming Z Trio 16GB Dark Base Pro 900 (Orange)  | TOSHIBA 4TB 3.5" Drive - Game Drive | KINGSTON SNVS1000G 1TB M.2 NVME SSD - Boot Drive | FSP Hydro PTM PRO 1000W |
Living Room PC: AMD Ryzen 2400G | MSI RX VEGA 56 8GB AERO | 2x8 GB Crucial Ballistix 2400MHz | Intenso 250GB SSD | Seagate 500 GB HDD | Node 202 + 850W PSU |
https://linustechtips.com/topic/1111295-delay-when-letting-go-of-throttle-of-car/
That sounds like rev hang (a "feature" added by manufacturer to reduce emissions)
8 minutes ago, Bitter said:
If the car has electronic throttle that's exactly what it is. If the car has cable throttle there could be something else awry.
I saw the video about rev hang here:
https://www.carthrottle.com/post/rev-hang-explained-and-why-petrolheads-hate-it/
Definitely not reacting as fast as this guys car. The revs stay constant for about a second, don't drop at all on mine. It's only after a second they start to drop.
6 minutes ago, circeseye said:
rev hang? um no and especially that year and its a stick
that sounds like your throttle is sticking slightly...might be gunked up at the throttle body
So basically try cleaning the throttle body? (the flipping lid thingy)
