How do I control the pump and CPU block fan speeds on my Asus ROG Ryujin 360? Thanks!
  • My system specs
  • View 91 Tempered Glass RGB Edition, No PSU, XL-ATX, Black, Full Tower Case
  • ROG MAXIMUS XI EXTREME, Intel Z390 Chipset, LGA 1151, HDMI, E-ATX Motherboard
  • Core™ i9-9900K 8-Core 3.6 - 5.0GHz Turbo, LGA 1151, 95W TDP, Processor
  • GeForce RTX™ 2080 Ti OC ROG-STRIX-RTX2080TI-O11G-GAMING, 1350 - 1665MHz, 11GB GDDR6, Graphics Card
  • ROG RYUJIN 360, 360mm Radiator, Liquid Cooling System
  • 32GB Kit (2 x 16GB) Trident Z DDR4 3200MHz, CL14, Silver-Red DIMM Memory
  • AX1600i Digital, 80 PLUS Titanium 1600W, Fanless Mode, Fully Modular, ATX Power Supply
  • Formula 7, 4g, 8.3 (W/m-K), Nano Diamond, Thermal Compound
  • On AIO cooler 6 x NF-F12 IPPC 3000 PWM 120x120x25mm 4Pin Fibre-glass SSO2 Heptaperf Retail
  • 6 x NF-A14 IPPC-3000 PWM 140mm, 3000 RPM, 158.5 CFM, 41.3 dBA, Cooling Fan
  • 1TB 970 PRO 2280, 3500 / 2700 MB/s, V-NAND 2-bit MLC, PCIe 3.0 x4 NVMe, M.2 SSD
  • Windows 10 Pro 64-bit
  • Beyerdynamic MMX 300 (2nd Generation) Premium Gaming Headset
  • ROG PG279Q
  • Corsair K95 Platinum XT
  • ROG Sica
Are you referring to the system in your sig?
Plug the fans into the splitter from the cooler and plug them pump header into the aio_pump header if there is one or the cpu_fan1 header.
Afterwards, look for the Ryujin fan and pump controls in Fan Xpert 4.
Got it will check in Fan Xpert4 in AI Suite 3. Thanks!
  • My system specs
  • ROG PG279Q
  • ROG Sica
