After a lot of research I have finalized a Ryzen 2600 based PC with following configuration. But I am confused again as AMD has just launched Ryzen 3500 in India, priced at ~₹11200, which is on many articles referred as 'killer'. My question is, should I consider swapping 2600 (priced ~₹14000)  for 3500 ( I believe, I may not have to change rest of the hardware)?
I would also like to mention that I will not be playing games on this machine.
  • MSI B450M MORTAR MAX
  • 16 GB DDR-4 G-SKILL RIPJAWS (3000 FSB)
  • 240GB SSD
  • 450W MasterCooler
  • RX 570 Gigabyte
Thank you
i think 2600 is better
  • CPU
    AMD Ryzen™ 7 5800X 4.7Ghz
  • Motherboard
    MSI MEG X570 ACE
  • RAM
    G.SKILL Trident Z Royal Series 32GB (2 x 16GB) F4-3200C16D-32GTRS
  • GPU
    GeForce RTX™ 3060 EAGLE OC 12G (rev. 2.0)
  • Case
    Cooler Master MASTERBOX MB520 ARGB + Cooler Master MasterFan MF120R ARGB
  • Storage
    ADATA XPG SX8100 2TB PCIe Gen3x4 M.2 2280 SSD
    ADATA LEGEND 960 4TB PCIe Gen4x4 M.2 2280 SSD
    ADATA Ultimate SU800 2TB 2.5" SSD
    Crucial BX500 2TB 3D NAND SATA 2.5-inch SSD
    Toshiba X300 4TB 7200 RPM
    TOSHIBA MG06 (MG06ACA10TE) 10TB 3.5 Inch 7200RPM Enterprise SATA Hard Drive
  • PSU
    Cooler Master MWE GOLD 750 FULL MODULAR
  • Display(s)
    Acer KG271B Gaming Monitor (HDR Ready 27" 1920X1080 240Hz)
    MSI PRO MP241
  • Cooling
    Cooler Master MASTERLIQUID ML240R RGB
  • Keyboard
    MSI Vigor GK80 RED GAMING KEYBOARD
  • Mouse
    Razer Naga Hex Wraith Red Edition Wired Laser Mouse
  • Operating System
    Windows 11 Home
  • Router
    tp-link EB810v BE22000 Tri-Band Wi-Fi 7 VoIP Router
    Asus ROG Rapture GT-AX 11000
  • Network Card
    tp-link Archer TBE550E BE9300 Wi-Fi 7 Bluetooth 5.4 PCIe Adapter
  • 240GB SSD
  • 450W MasterCooler
  • RX 570 Gigabyte
Thank you
killer for 9400F not for 3600. the cache is far better on 3600. and also additional 100mhz clock speed.
  Spec: Macbook Air 2017
ProcessorPU: ii5 (I5-5350U |
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
 | GPU: Intel HD 6000 |
| Audio: JBL 450BT Wireless Headset |
If the R5 3500 is actually cheaper I'd consider it for a gaming focused build since it's single core performance is better... you can get around the lack of SMT by simply not having a lot of sideground programs running with your game.
Personal Desktop":
Luna, the temporary Desktop:
28 minutes ago, pkr said:
2600 and not 3600. 3500 is cheaper than 2600.
The 3500 is essentially a 3600 with no SMT, and the IPC gains made by Zen2 make it a faster overall CPU
If its cheaper than the 2600 I don't see why you'd want the 2600
CPU: AMD Ryzen 5 3600  Heatsink: ID-Cooling Frostflow X GPU: Zotac GTX 1060 Mini 6GB RAM: KLEVV Bolt 3600Mhz (2x8GB) Mobo: ASUS B550-F ROG Strix (Wifi)  Case: Fractal Design Meshify C PSU: Deepcool DQ-M-V2L
  • 240GB SSD
  • 450W MasterCooler
  • RX 570 Gigabyte
Thank you
What are you going to do if not playing games on it??
For productivity workloads r5 2600 would be better , but it also depends on the software you are using , as it can make use of threads or not.
no SMT no care, skip it.
Before you reply to my post, REFRESH. 99.99% chance I edited my post.
My System: i7-13700KF // Corsair iCUE H150i Elite Capellix // MSI MPG Z690 Edge Wifi // 32GB DDR5 G. SKILL RIPJAWS S5 6000 CL32 // Nvidia RTX 4070 Super FE // Corsair 5000D Airflow // Corsair SP120 RGB Pro x7 // Seasonic Focus Plus Gold 850w //1TB ADATA XPG SX8200 Pro/1TB Teamgroup MP33/2TB Seagate 7200RPM Hard Drive // Displays: LG Ultragear 32GP83B x2 // Royal Kludge RK100 // Logitech G Pro X Superlight // Sennheiser DROP PC38x
